2 Replies Latest reply on May 30, 2007 12:59 PM by McFazstp
    A text question
    wgb14 Level 1
      Hi all,
      Does anyone know how can i check if a text cast member contains text ? What i would like to do is the following
      case true of
      (member("Level1").text = ) --- any text in the cast member input will validate this
      end case
      case true of
      (member("Level1").text = EMPTY):
      --do somethign here
      end case
      I tried member("Level1").text = member("Level1").text which works but it gives me very long case staments (something which i want to avoid). Any ideas?
        • 1. Re: Cast member question
          Level 7
          if member("Level1").text <> "" then
          --do stuff
          end if
          "wgb14" <webforumsuser@macromedia.com> wrote in message
          news:f3k5ok$9lv$1@forums.macromedia.com...
          > Hi all,
          > What i
          > case true of
          > will
          > validate this
          > end case
          > case true of
          > --do somethign here
          > end case
          > ideas?
          > Thanks
          • 2. Re: A text question
            McFazstp
            If you just want to check if it is empty;
            if (member("Level1").text = EMPTY) then
            -- it's empty
            else
            -- it's got text in it
            end if
            If you want to be more specific
            case ( member("Level1").text ) of
            "Hello":
            "Goodbye":
            "etc":
            EMPTY:
            end case
