1 Reply Latest reply on Apr 17, 2014 9:55 AM by ZTH002
    Changing all list entires from another field
    ZTH002
      So Im working on a new form and I need to move my data around. The attached PDF is windjacks tut that works great but I cant figure out how to get it to work with what Im doing. I have been trying to piece together all the javascript from this and other tutorials and havent had much luck.
      All the drop downs effect the next from left to right. So looking at the bottom row that I put in Row.AssemblySelect will fill in new data into Row3.PartSelect. When Row3PartSelect data is selected new data will fill Row3PackageSelect. I tried to make this work with a new SetPackageEntries(); command modeled off the SetPartEntries(); with some varable changes but I couldnt get it to work. Then, finally, after making a selection in Row3PackageSelect data needs to be distrubred to 6 or more different cells that you can see under the Row3.Price.
      https://dl.dropboxusercontent.com/u/2944617/00%20work/ListPrograming_Part1_AcroForm%202.pd f
      Hope I explained clearly. Appericate the help!
      -Zach
