3 Replies Latest reply on Apr 18, 2014 3:26 AM by JEShort01
      • 1. Re: RAM for Premier PRO CC
        JEShort01 Level 4
        You are right in choosing 32GB as a good fit for the rest of your system.
        I will only comment on G Skill as I have personally had good luck with their RAM (always from Newegg) over the years in various Gigabyte and Asus builds.
        Suggest you use:
        - 1600MHz (sweet spot; slower is slower, and faster buys you very, very, very little for Adobe CC)
        - CAS 9/9/9/24 should be fine; get faster if the incremental cost is slight
        - 1.5v or less
        - sticks sold in a 32GB set
        - exact p/n's listed on G Skill's web site RAM configurator for your exact motherboard; this tool is under the "support" menu on their web site which is not where one might expect to find it
        • 2. Re: RAM for Premier PRO CC
          mongol-style Level 1
          Thank you for you comment.
          My motherboard support  DDR3 2133/1866/1600/1333/1066 MHz memory modules
          My CPU support only DDR3-1066/1333
          Will my system work with DDR3 2133MHz ????
          • 3. Re: RAM for Premier PRO CC
            JEShort01 Level 4
            Yes, 2133 MHz should work.
            Again, your speed gains vs. 1600 MHz memory will be marginal so don't spend too much extra for the faster sticks.
