13 Replies Latest reply on Apr 24, 2014 6:53 AM by Das0627
    Java help Needed
    Das0627
      I am looking to have a checkboxes to check automatically based on what is selected on the dropdown list.
      Such as
      DepartmentUser1 needs to have access to system1 system 2 system 3
      DepartmentUser2 needs to have access to system1 system3 system 4 and system 35
      DepartmentUser3 needs to have access to system22 system28
      DepartmentUser4 needs to have access to system49
      I had used the code I had found earlier but it does not let me select multiple checkboxes...
      The Department Users all have different export values such as 1 2 3 etc...
      Here is the code I had found earlier (I used it in the Custom Calculation Field)
      var drop = this.getField("Dropdown1");
      var check = this.getField("ADP");
      if ((drop.value == 1) || (drop.value == 2)){
      check.checkThisBox(0,true);
      else {
      check.checkThisBox(0,false);
      I am using Adobe Acrobat Pro X.
      Thank you for any and all help.
