1. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
mec_os Apr 17, 2014 12:52 PM (in response to Leon123211)what kind of file are you embedding?
when you link a file(assuming ai file), illustrator treats it as a PDF which will have clipping masks. instead of embedding the files, open them and copy and paste the contents into your ai document.
2. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
Monika Gause Apr 17, 2014 12:52 PM (in response to Leon123211)Copy and paste instead of placing.
With placing you use the PDF part of the file which almost always will have lots of masks.
3. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
Leon123211 Apr 17, 2014 12:59 PM (in response to Leon123211)I will be doing this for multiple files and really need to embed external files to optimize my workflow as opposed to Copy and Paste solution. But I guess if there is not way to avoid the masks I'll just have to do it manually.
4. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
Monika Gause Apr 17, 2014 1:15 PM (in response to Leon123211)Linking files has actually some advantages over Copy/Paste. Embedding files: not so much.
5. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
Leon123211 Apr 17, 2014 1:21 PM (in response to Monika Gause)Monica, I will be linking, but need to embed the linked files prior to delivering the final work to a third party.
6. Re: How to incorporate gradient fill in embedded files in Illustrator CC?
mec_os Apr 17, 2014 6:00 PM (in response to Leon123211)will this affect said third party?
if you must, after you embed, select the mask lines and delete them. i usually select with the group select tool or with the wand tool. i can't tell you what quality your art will be after doing this. sometimes gradient get expanded in PDFs.
