2 Replies Latest reply on Apr 29, 2014 7:40 AM by sashaa777
    Why filters are not awailable for my objects?
    sashaa777
      Why filters are not awailable for my objects?Снимок экрана 2014-04-19 в 19.30.24.png
        • 1. Re: Why filters are not awailable for my objects?
          heathrowe Most Valuable Participant
          Based on your screenshot preview, I can see that from your Elements panel, you are using an external .html file, correct?
          Some in-app Properties are not available for external, non-managed files.
          If you create a new project (File > New), for example, add an element you will have full access to Edge Animate properties.
          If you create a htm5 doc in Dreamweaver, for example, and open that in Edge Animate then you are limited - because the originating file (.html) is from another application.
          Hope this helps, clarify.
          Darrell
          • 2. Re: Why filters are not awailable for my objects?
            sashaa777 Level 1
            Hello. Thanks for the replay. Indeed that page first was created in DreamWaver and then i wanted to modifie  it in Edge Animate.
            Hopefuly Adobe will improve this.
