23 Replies Latest reply on Sep 24, 2015 4:11 PM by EWG2015
    How can i fix blank "File Info...." in Photoshop CS5?
    Vanillaman
      I wanted to add metadata to some of my photos. However, when I attempted to open "File Info" there was nothing in the dialogue box. It was just empty. Is there a method for fixing this apart from reinstalling Photoshop?
        • 1. Re: How can i fix blank "File Info...." in Photoshop CS5?
          Trevor.Dennis Adobe Community Professional (Moderator)
          Use Bridge to edit Metadata.
          • 2. Re: How can i fix blank "File Info...." in Photoshop CS5?
            Vanillaman Level 1
            Thank you. However, it doesn't really answer my question?
            • 3. Re: How can i fix blank "File Info...." in Photoshop CS5?
              Chuck Uebele Adobe Community Professional & MVP
              Try updating Flash.  Also check your XMP directory.  On Windows, it's C:\Program Files (x86)\Common Files\Adobe\XMP\Custom File Info Panels\3.0.  There should be lots of subfolders containing each of the different panels within the info panel.  They should all have a swf file in the bin folder, including the main 3.0 sub-folder.  Each folder should also have a file called manifest.xml.
              • 4. Re: How can i fix blank "File Info...." in Photoshop CS5?
                Vanillaman Level 1
                Thank you. There is is no manifest.xml. I read somewhere that I just needed to create an xml and place it in one of the folders. However, I don't know what I'm supposed to write in the xml file and where to put it??
                • 5. Re: How can i fix blank "File Info...." in Photoshop CS5?
                  No you don't want to write your own, unless you're creating your own custom metadata panel.  You might have to reinstall PS to have them install properly, unless you know someone else who has CS5 and just copy the whole file structure.
                  • 6. Re: How can i fix blank "File Info...." in Photoshop CS5?
                    Vanillaman Level 1
                    Sorry. Perhaps I didn't explain properly. I don't mean `write my own' xml file. Someone suggested creating another copy of the missing one, but stopped short of how to do that and what data it included? Perhaps the missing file is the manifest.xml as I previously mentioned. What information does that contain? Also, I don't wish to reinstall PS again while there is an alternative solution and I've already tried that??
                    • 7. Re: How can i fix blank "File Info...." in Photoshop CS5?
                      This might also have something to do with your graphics card.
                      I don't have cS5 loaded, but it might be close to what CS6 has  There are some differences in the acutal panels between the two, but that might be in relation to the swf files.  The main file structure looks something like this:
                      C:\Program Files (x86)\Common Files\Adobe\XMP\Custom File Info Panels\3.0 with these folders under 3.0: AMT, bin, custom, panels.  There are no files under this folder.
                      Under the "panels" folder there are all the folders of the tabs: Advanced, audioData, camera, categories, description, dicom, gpsData, history, IPTC, IPTCExt, mobile, origin, rawpacket, and videoData.
                      Under each of these are folders: bin and location.  And the one file manifest.xml.
                      Advanced:
                      <xfi:fileinfo xmlns:xfi="http://ns.adobe.com/xmp/fileinfo/">
                          <xfi:panels>
                              <xfi:panel
                                  name = "advanced"
                                  label = "$$$/AWS/FileInfoLib/Panels/Advanced/PanelName=Advanced"
                                  order = "200"
                                  description = "$$$/AWS/FileInfoLib/Panels/Advanced/PanelDescription=Displays the XMP data in a tree view."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "advanced"
                                  panelClass = "com.adobe.xmp.panels.Advanced"
                                  localizationFile = "Advanced"
                                  visible = "true"
                                  modifyDate = "2008-03-04Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      audioData:
                          <xfi:panels>
                              <xfi:panel
                                  name = "audio"
                                  label = "$$$/AWS/FileInfoLib/Panels/DynamicMedia/AudioData/PanelName=Audio Data"
                                  order = "50"
                                  description = "$$$/AWS/FileInfoLib/Panels/DynamicMedia/AudioData/PanelDescription=Contains the most important audio properties."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "audioData"
                                  panelClass = "com.adobe.xmp.panels.AudioData"
                                  localizationFile = "AudioData"
                                  visible = "true"
                                  modifyDate = "2008-01-28Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      camera:
                          <xfi:panels>
                              <xfi:panel
                                  name = "camera"
                                  label = "$$$/AWS/FileInfoLib/Panels/Camera/PanelName=Camera Data"
                                  order = "30"
                                  description = "$$$/AWS/FileInfoLib/Panels/Camera/PanelDescription=Contains the most important TIFF and Exif properties."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "camera"
                                  panelClass = "com.adobe.xmp.panels.CameraData"
                                  localizationFile = "Camera"
                                  visible = "true"
                                  modifyDate = "2008-01-21Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      categories:
                          <xfi:panels>
                              <xfi:panel
                                  name = "categories"
                                  label = "$$$/AWS/FileInfoLib/Panels/Categories/PanelName=Categories"
                                  order = "70"
                                  description = "$$$/AWS/FileInfoLib/Panels/Categories/PanelDescription=Image Categories"
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "categories"
                                  panelClass = "com.adobe.xmp.panels.Categories"
                                  localizationFile = "Categories"
                                  visible = "true"
                                  modifyDate = "2008-01-29Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      description:
                          <xfi:panels>
                              <xfi:panel
                                  name = "description"
                                  label = "$$$/AWS/FileInfoLib/Panels/Description/PanelName=Description"
                                  order = "10"
                                  description = "$$$/AWS/FileInfoLib/Panels/Description/PanelDescription=Contains the core properties of the asset."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "description"
                                  panelClass = "com.adobe.xmp.panels.Description"
                                  localizationFile = "description"
                                  visible = "true"
                                  modifyDate = "2007-09-13Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      dicom:
                          <xfi:panels>
                              <xfi:panel
                                  name = "dicom"
                                  label = "$$$/DICM/FileInfoLib/Panels/DICOM/PanelNameAllLang=DICOM"
                                  order = "90"
                                  description = "$$$/DICM/FileInfoLib/Panels/DICOM/PanelDescription=Digital Imaging and Communications in Medicine."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "dicom"
                                  panelClass = "com.adobe.xmp.panels.Dicom"
                                  localizationFile = "DICOM"
                                  visible = "true"
                                  modifyDate = "2007-12-10Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      gpsData:
                          <xfi:panels>
                              <xfi:panel
                                  name = "gpsData"
                                  label = "$$$/AWS/FileInfoLib/Panels/GPSData/PanelName=GPS Data"
                                  order = "35"
                                  description = "$$$/AWS/FileInfoLib/Panels/GPSData/PanelDescription=Contains the EXIF GPS tag properties."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "gpsData"
                                  panelClass = "com.adobe.xmp.panels.GPSData"
                                  localizationFile = "GPSData"
                                  visible = "true"
                                  modifyDate = "2011-08-15Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      history:
                          <xfi:panels>
                              <xfi:panel
                                  name = "history"
                                  label = "$$$/AWS/FileInfoLib/Panels/History/PanelName=History"
                                  order = "100"
                                  description = "$$$/xmp/photoshop/History_description=The Photoshop History displays an accumulated log of edit history that has been done to the document. The logging capability can be turned on via the PS preference dialog under General>History Log."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "history"
                                  panelClass = "com.adobe.xmp.panels.History"
                                  localizationFile = "History"
                                  visible = "true"
                                  <filter type="show" ignore="false">
                                      <mimetype>application/vnd.adobe.photoshop</mimetype>
                                  </filter>
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      IPTC:
                          <xfi:panels>
                              <xfi:panel
                                  name = "IPTC"
                                  label = "$$$/AWS/FileInfoLib/Panels/IPTC/PanelName=IPTC"
                                  order = "20"
                                  description = "$$$/AWS/FileInfoLib/Panels/IPTC/PanelDescription=International Press Telecommunications Council Core schema properties."
                                  paneltype = "built-in"
                                  version = "1.0"
                                  panelLibrary = "iptc"
                                  panelClass = "com.adobe.xmp.panels.IPTC"
                                  localizationFile = "IPTC"
                                  visible = "true"
                                  modifyDate = "2008-04-01Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      IPTCExt:
                          <xfi:panels>
                              <xfi:panel
                                  name = "IPTCExt"
                                  label = "$$$/AWS/FileInfoLib/Panels/IPTCExt/PanelName=IPTC Extension"
                                  order = "25"
                                  description = "$$$/AWS/FileInfoLib/Panels/IPTCExt/PanelDescription=International Press Telecommunications Council Extension schema properties."
                                  version = "1.0"
                                  panelLibrary = "iptcExt"
                                  panelClass = "com.adobe.xmp.panels.IPTCExt"
                                  localizationFile = "IPTCExt"
                                  visible = "true"
                                  modifyDate = "2009-06-12Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      mobile:
                          <xfi:panels>
                              <xfi:panel
                                  name = "mobile"
                                  label = "$$$/AWS/FileInfoLib/Panels/Mobile/PanelName=Mobile SWF"
                                  order = "60"
                                  description = "$$$/AWS/FileInfoLib/Panels/Mobile/PanelDescription=Lets you define metadata of a mobile SWF document."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "mobile"
                                  panelClass = "com.adobe.xmp.panels.Mobile"
                                  localizationFile = "Mobile"
                                  visible = "true"
                                  modifyDate = "2008-02-21Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      origin:
                          <xfi:panels>
                              <xfi:panel
                                  name = "origin"
                                  label = "$$$/AWS/FileInfoLib/Panels/Origin/PanelName=Origin"
                                  order = "80"
                                  description = "$$$/AWS/FileInfoLib/Panels/Origin/PanelDescription=Displays information about the origin of the asset."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "origin"
                                  panelClass = "com.adobe.xmp.panels.Origin"
                                  localizationFile = "origin"
                                  visible = "true"
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      rawpacket:
                          <xfi:panels>
                              <xfi:panel
                                  name = "rawpacket"
                                  label = "$$$/AWS/FileInfoLib/Panels/RawData/PanelName=Raw Data"
                                  order = "210"
                                  description = "$$$/AWS/FileInfoLib/Panels/RawData/PanelDescription=Displays the XMP packet in raw RDF/XML form."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "rawpacket"
                                  panelClass = "com.adobe.xmp.panels.RawPacket"
                                  localizationFile = "Rawpacket"
                                  visible = "true"
                                  modifyDate = "2008-02-22Z">
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      videoData:
                          <xfi:panels>
                              <xfi:panel
                                  name = "video"
                                  label = "$$$/AWS/FileInfoLib/Panels/DynamicMedia/VideoData/PanelName=Video Data"
                                  order = "40"
                                  description = "$$$/AWS/FileInfoLib/Panels/DynamicMedia/VideoData/PanelDescription=Contains the most important video properties."
                                  type = "built-in"
                                  version = "1.0"
                                  panelLibrary = "videoData"
                                  panelClass = "com.adobe.xmp.panels.VideoData"
                                  localizationFile = "VideoData"
                                  visible = "true"
                              </xfi:panel>
                          </xfi:panels>
                      </xfi:fileinfo>
                      • 8. Re: How can i fix blank "File Info...." in Photoshop CS5?
                        Vanillaman Level 1
                        I don't seem to be getting anywhere with this. I should have bookmarked the possible solutions I read elsewhere, as they suggested creating or downloading a missing xml file.
                        • 9. Re: How can i fix blank "File Info...." in Photoshop CS5?
                          As I also mentioned, it might be the graphics card.  See:
                          https://answers.yahoo.com/question/index?qid=20101009142157AAMIQCy
                          It might be that whatever card you have isn't sending info that PS can use to detect what card you have.  Looks like even brand new cards can cause this, as the older version of PS doen't recognize them.
                          • 10. Re: How can i fix blank "File Info...." in Photoshop CS5?
                            R_Kelly Adobe Community Professional
                            You haven't said what operating system your using.
                            For windows maybe this will work:
                            http://www.dpreview.com/forums/post/41020959
                            this is what it says:
                            I found this remedy and IT WORKS!
                            (I am running Win 7 Professional 64-bit and Photoshop CS5 Ext)
                            Create a new text file named XMP.cfg (make sure the extension is cfg and not txt).
                            The only text that needs to be in that file is as below:
                            C:\
                            Copy the file to C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerTrust
                            (create the directory if not already there).
                            Restart the Adobe application and check the File Info"
                            If you go to
                            do you have a file named
                            AdobeXMPFileInfoCS5.cfg
                            • 11. Re: How can i fix blank "File Info...." in Photoshop CS5?
                              R_Kelly, the OP is using Win 7.  There was another post in a similar thread:
                              http://forums.adobe.com/message/6318120#6318120
                              I saw that link that you posted also, and would be leary about making a trust file that blanketed your entire hard drive.  Seems to me that would allow any hacker to install a flash program anywhere on your computer.
                              • 12. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                Vanillaman Level 1
                                Hi
                                Thank you. I got as far as: C:\Windows\SysWOW64\Macromed\Flash\  However, there was no FlashPlayerTrust and no file named AdobeXMPFileInfoCS5.cfg either??
                                • 13. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                  It might be best to unistall/reinstall photoshop cs5.
                                  What operating system are you using?
                                  • 14. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                    Just create the rest of the folders.  The config file is just a plain text file with the extension .cfg.  All you do is put the path to where the file info panels are.  It should be:
                                    • 15. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                      That wouldn't be a bad idea, R_Kelly.  Especially if creating the trust file doesn't work.
                                      • 16. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                        Vanillaman Level 1
                                        I already tried reinstalling previously. When I follow the path, C:\Program Files (x86)\Common Files\Adobe\XMP, all that is listed are folders: 2.0, 3.0 and the Illustrator.txt file. Where do I go from there? Also, if I create a new text file named XMP.cfg, as suggested, what are its contents and where do I place it if there is no FlashPlayerTrust file??
                                        • 17. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                          This is the contents of the trust file.  The trust file and the cfg file are the same thing.  You can stop at the folder XMP, as that should give Flash permisstion to run any flash (swf) file in that folder or any in a subdirectory of that folder, so that will cover all the way down to you 2.0 and 3.0 folders.
                                          • 19. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                            Vanillaman Level 1
                                            Thank you. So I created the XMP.cfg.txt file with this as the only text: C:\Program Files (x86)\Common Files\Adobe\XMP. I then placed it into the "Custom File Info Panels" folder. I started up Photoshop and opened an image, then went to "File Info..". Still a blank dialogue box appears. I even tried placing the XMP.cfg.txt file in just the XMP folder, but still nothing worked??
                                            • 20. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                              No, you need to name the file with the extension .cfg and do not put the txt at the end.  It needs to be a cfg file not a txt file.  Also you need to put that file in the folder:
                                              If those folders don't exists, make them.
                                              • 21. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                                Vanillaman Level 1
                                                Csuebele, Thank you so much. That solution finally worked. You have been a great help, as has everyone who contributed. I can't thank you all enough for your wonderful support and patience.
                                                • 22. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                                  So glad you finally got it working.
                                                  Chuck
                                                  • 23. Re: How can i fix blank "File Info...." in Photoshop CS5?
                                                    EWG2015 Level 1
                                                    An internet search led me to this forum. I had the same blank EXIF window problem in PSE 11. Adding the FlashPlayerTrust folder and the xmp.cfg file worked for PSE 11, too. Thanks !
