6 Replies Latest reply on May 24, 2007 6:47 AM by MacAnthony
    DataGrid with Row numbers
    MacAnthony
      I would like to be able to have a column of line numbers for my datagrid, but I need the numbers to only be a row count and not associated with the row. What I mean is, the datagrid will be sortable so I don't want the row numbers to sort along with the other data. Is this possible? Or would a custom component need to be made?
        • 1. Re: DataGrid with Row numbers
          JabbyPandaUA Level 3
          AFAIK is it not possible to a column in a Datagrid that does not obey sorting rules...
          You can display next to Datagrid another List with row index only displayed.
          • 2. Re: DataGrid with Row numbers
            MacAnthony Level 1
            that sounds like an option but then how do you keep the other list scrolling along with the datagrid list?
            • 3. Re: DataGrid with Row numbers
              bind selectedIndex of mx:List control to selectedIndex of mx:DataGrid control
              <mx:List is="ids" selectedIndex="{dataGrid.selectedIndex}" />
              <mx:Datagrid is="dataGrid" />
              • 4. DataGrid with Row numbers
                BLXWebMaster Level 1
                Come On. Anything is possible. How do you get the ability to specify that a message is an answer? :-)
                Although not easy, with help I was able to get the functionality you are looking for. Basically a row number indicator that stays static if the columns are sorted.
                In your DataGrid you specify the column you want to display itemRenderer = rowNum.
                Create a Component called rowNum.mxml.
                rowNum.mxml
                <mx:Label xmlns:mx=" http://www.adobe.com/2006/mxml">
                <mx:Script>
                <![CDATA[
                import mx.controls.DataGrid;
                import mx.controls.dataGridClasses.DataGridListData;
                override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number):void
                super.updateDisplayList( unscaledWidth, unscaledHeight );
                var dgListData:DataGridListData = listData as DataGridListData;
                var dataGrid:DataGrid = dgListData.owner as DataGrid;
                this.text = String(listData.rowIndex + dataGrid.verticalScrollPosition);
                callLater(foo);
                private function foo():void{
                invalidateDisplayList();
                </mx:Script>
                </mx:Label>
                Should work like a charm.
                Allen
                • 5. Re: DataGrid with Row numbers
                  Dear Allen,
                  You are right, by using custom item renderer and relying on listData.rowIndex property and dataGrid.verticalScrollPosition property we can construct a datagridColumn that displays row indexes that are independent from sorting rules set in our DataGrid.
                  Listen to Allen, he is a star :)
                  Here is my slightly modified code for itemRenderer based on Allen's idea.
                  I only added a check if listData variable is not equal to NULL, it was giving me some runtime errors in Flash player
                  package {
                  import mx.controls.Label;
                  import mx.controls.dataGridClasses.*;
                  import flash.display.Graphics;
                  public class rowNum extends Label {
                  super.updateDisplayList(unscaledWidth, unscaledHeight);
                  var g:Graphics = graphics;
                  g.clear();
                  if (listData != null ) {
                  Assigning this item renderer to dataGrid:
                  <mx:DataGrid id="myGrid">
                  <mx:columns>
                  <mx:DataGridColumn headerText="test" itemRenderer="rowNum"/>
                  <mx:DataGridColumn headerText="First Name" dataField="firstName"/>
                  </mx:columns>
                  </mx:DataGrid>
                  • 6. Re: DataGrid with Row numbers
                    MacAnthony Level 1
                    Sorry, I didn't mark it as an answer until it looked like I wasn't gonna be getting any more responses. That and the fact that JP did give a solution. I guess I'm impatient :)
                    If I could undo it, I would, but there doesn't seem to be a way.
