1 Reply Latest reply on Apr 20, 2014 3:47 PM by Lucia Lao
    How to redistribute/edit a drop down menu or a bullet menu?
    coconotes
      Listen .. do you want to help or not?
      After listing for a drop down menu I want to edit it and move say #5 to #2.  How do I do that in Forms Central?
        • 1. Re: How to redistribute/edit a drop down menu or a bullet menu?
          Lucia Lao Employee Moderator
          There is no drag and drop feature for what you have described. You need to manually change them, this is, you may need to delete one of the choice-options  that you like to swap, manually change the other, and then add the second choice-options at the other desired location.
          Hope this helps,
          Lucia
