1. Re: Issues with importing FM Glossary into RH
Jeff_Coatsworth Apr 22, 2014 5:20 AM (in response to Sreekanth_S)I think you’ve a space after your colon in the marker text – that might be throwing it off
2. Re: Issues with importing FM Glossary into RH
Sreekanth_S Apr 22, 2014 7:37 AM (in response to Jeff_Coatsworth)I removed the space. Still no use.
Sreekanth
3. Re: Issues with importing FM Glossary into RH
Jeff_Coatsworth Apr 22, 2014 7:53 AM (in response to Sreekanth_S)What version of TCS are you doing this in?
See if this thread helps - http://forums.adobe.com/message/1043852#1043852
4. Re: Issues with importing FM Glossary into RH
Sreekanth_S Apr 22, 2014 8:02 AM (in response to Jeff_Coatsworth)I am using TCS4.
Even the GLO file is showing incorrect format.
<glossentry>
<glossterm>Second level alphabetical list:This is the glossary description for 2nd level bulleted list.This</glossterm>
<glossdef>This is the example of second level alphabetical list. In FrameMaker, this is shown as a. something. In RoboHelp it might be different. This is some additional text added to check the text indentation.</glossdef>
</glossentry>
Sreekanth
5. Re: Issues with importing FM Glossary into RH
max_drawdown Sep 3, 2014 9:58 AM (in response to Sreekanth_S) -
6. Re: Issues with importing FM Glossary into RH
Jeff_Coatsworth Sep 3, 2014 10:11 AM (in response to max_drawdown)@max_drawdown – it just may be a limitation of the FM to RH integration that it can’t handle multi-level glossary entries; it’s probably got the same problem with multi-level index entries too
7. Re: Issues with importing FM Glossary into RH
Sreekanth_S Sep 3, 2014 11:46 AM (in response to Jeff_Coatsworth)@max_drawdown: The issue is not resolved. We decided to drop that feature then. However, now that you reminded me I have logged a bug report with Adobe. I will keep you posted on any update I receive.
@Jeff_Coatsworth: I guess I took the wrong term here as an example. The glossary and the Index are at first level only. No issues with the Index though.
Sreekanth
8. Re: Issues with importing FM Glossary into RH
Jeff_Coatsworth Sep 3, 2014 12:08 PM (in response to Sreekanth_S)So have you ever tried bringing over a multi-level index entry? It never worked for me because of a fatal crash that FM would throw if you used the “book of books” concept with an entry like Animals:Canada:Beaver
9. Re: Issues with importing FM Glossary into RH
Sreekanth_S Sep 3, 2014 12:32 PM (in response to Jeff_Coatsworth)@Jeff
I had never tried.
But I did try now. I selected a text Animals on page 4 of 22 of my FM document, marked it as Index, and gave the text you mentioned in the Marker pod's Marker Text field.
On updating the book, the Index FM file had three levels. And, on importing it to RH, Index showed three levels in the Webhelp output.
However, I might be doing it wrong, as I am not sure what you meant by "Book of books" concept.
Sreekanth
10. Re: Issues with importing FM Glossary into RH
Jeff_Coatsworth Sep 3, 2014 12:39 PM (in response to Sreekanth_S)Nope, that’s exactly it – good to know it works ok.
I could never get the FM index to be generated correctly because there was a bug that caused FM to blow up. It only happened when you had a master book that had your ToC and Index (both all based on .fm files contained within “sub-books”), and the sub-books themselves. So you would have a master book that had sub-books (like modules), each of which had a number of .fm files making them up – a “book of books” concept.
