9 Replies Latest reply on Jun 1, 2007 4:30 PM by Sarah_G_Vinci
    Menu Drop Down help
    gkeg
      I have created a menu bar with drop down menus on my company's website. The only problem is that every time I want to change something in that menu bar, I have to go and edit the toolbar in each page that it is in; otherwise the new links (or changed ones) do not get updated globally in the toolbar. Is there any way of making the toolbar so that whenever I would like to change something, or add a new page, I can just make one change and have that change made in the toolbar globally?
        • 1. Re: Menu Drop Down help
          gkeg Level 1
          quote:
          I should add that I have created the menu in Fireworks and exported it to Dreamweaver.
          • 2. Re: Menu Drop Down help
            Sarah_G_Vinci
            I am having the same problem! I have created 7 different banners each with the same row of drop down menus; and they are now inserted into over 50 different pages of the website. Every time I edit those menus in Fireworks 8, the changes do not appear. I have literally had to recreate the entire pages in dreamweaver 8! This is like starting all over again to build a new site. Have you found a solution yet? Please share, thanks, Sarah
            • 3. Re: Menu Drop Down help
              Level 7
              Editing in Fireworks can't change files on your Web server. Any changes
              you make would have to be imported into the Dreamweaver page, and then
              from Dreamweaver, uploaded to the Web site.
              Linda Rathgeber [PVII] *Adobe Community Expert-Fireworks*
              http://www.projectseven.com
              Fireworks Newsgroup: news://forums.projectseven.com/fireworks/
              CSS Newsgroup: news://forums.projectseven.com/css/
              http://www.adobe.com/communities/experts/
              • 4. Re: Menu Drop Down help
                Level 7
                No, there isn't. No matter which menu model you use, you'll always have
                to update everything on the server manually. You might want to explore
                the subject of server side include commands.
                • 5. Re: Menu Drop Down help
                  Sarah_G_Vinci Level 1
                  But... I have exported the changed banner back into the site. If the dreamweaver page has the banner (Fireworks document that I just edited) contained in it. Why is it not recognizing it? I am not changing the name.
                  I am literally creating a new page, and reinserting the Fireworks banner, then I have to recreate the entire page. Because if I delete the banner off the page, and try to import it back in, my entire page is lost! I am feeling stupid and quite at a loss! Not to mention the hair loss.
                  • 6. Re: Menu Drop Down help
                    Level 7
                    What steps are you using to insert your banner? Is your site properly
                    defined in Dreamweaver? The reason for that last question is that unless
                    the site is defined ad a notes folder generated, Fireworks and
                    Dreamweaver cannot comunicate with each other properly.
                    • 7. Re: Menu Drop Down help
                      hmmm, well I followed Murray R. summers directive for creating and importing pop-up menus into Dreamweaver.
                      http://www.adobe.com/devnet/fireworks/articles/fw8_popups.html
                      the process worked fine on my personal site, but now I am building a site for work, with numerous more pages, and changes.
                      There is no notes folder.
                      process:
                      make changes to pgn file, save, file>update html
                      I have also tried dumping all files related to the banner, and saving & exporting is anew.
                      In dreamweaver I have a page with the old banner, now not recognizing the new changed one.
                      so on a blank page with curser where I want the banner I import the html document.
                      • 8. Re: Menu Drop Down help
                        Level 7
                        Is the site not defined, or have you disabled notes?
                        • 9. Re: Menu Drop Down help
                          The site is defined, although it is not live on a server yet. No I have not disabled notes
