3 Replies Latest reply on Apr 23, 2014 1:31 AM by Kai Rübsamen
    Find untag contents in XML workflow
    BEGINNER_X Level 3
      Hi All,
      Is it possible to find the untag contents in the xml workflow??
      (i.e.,) I need to alert the paragraph start with "Feria vendaepudae........" having untag contents.
      Kindly help to find the solution.
      Regards
      Siraj
        • 1. Re: Find untag contents in XML workflow
          Kai Rübsamen Level 4
          Hi Siraj,
          I did not work with xml, but I found a property 'associatedXMLElements' and create the following example:
          One textframe, a list with 5 paragraphs. The list is part of a xml-file and all paragraphs without the first and last paragraph are tagged.
          var tFrame = app.selection[0];
          var frameParas = tFrame.paragraphs;
          for ( var i = 0; i < frameParas.length; i ++ ) {
              var curPara = frameParas[i];
              if ( curPara.associatedXMLElements.length == 1 ) {
                  curPara.select();
                  alert( "Found" );
              } // end if
          } // end for
          The length of the 'associatedXMLElements' tagged paras is 2, while the length of the untagged paras is 1.
          hth
          –Kai
          • 2. Re: Find untag contents in XML workflow
            BEGINNER_X Level 3
            Hi Kai,
            Thank you for your helpful coding...
            But I run the same coding in the long file, it fails to produce the result.
            I also, just now started the xml workflow.
            Any other better solution is appreciable.
            Thanks in advance
            Siraj
            • 3. Re: Find untag contents in XML workflow
              Hm! If I have a look here with a filter "xml", there are not much attributes about xml, so I would think, we are on the right way?!
              http://yearbookmachine.github.io/esdocs/#/InDesign/Paragraph
              Maybe it is not a good idea, to hard code the length-value. What does the length-value tell you, if you control 'curPara' in the databrowser? Testfile??
