• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Problem with RoboHelp 6 (new purchase)
Explorer ,
May 23, 2007 May 23, 2007
Hi all,
Well I have just purchased the latest version of RoboHelp 6 and I opened my previous project (from RoboHelp X3) in the new RH. I managed to have everything working and everything was good for about a week (including command-line compilation and batch generates). However now when I open my project RH stalls. Sometimes it manages to open the project but I can never edit it. I don't believe this issue to have anything to do with my machine's specs and I am running RH on the local machine (where I have admin rights) as opposed to the network. I am a bit confused by this behaviour. Maybe I need a patch or something but I am unsure as to where to find one.
Thanks in advance for any advice on this issue,
darkagn
Views
508
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , May 23, 2007 May 23, 2007
Try opening the supplied sample projects and see if they have the same problem.
Assuming this confirms the problem is with your project rather than RoboHelp generally, see the topic on my site about opening projects. It explains about trashing the CPD and XPJ files.
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 06, 2007 Jun 06, 2007
Thanks Peter,
That fixed the problem right up For anyone else experiencing similar problems, the page Peter is referring to can be found by following this link.
Cheers
darkagn
Votes
Translate
Translate
Report
Report
Explorer ,
Jun 20, 2007 Jun 20, 2007
Hi Peter,
I have been experiencing the same problems again so I tried the tricks you mention on your site again. It has fixed the problem once more, but I did lose my new conditional build tags and my recently created single source layouts. It only took a few minutes to rectify, but I thought I might mention it as your site implies that these problems would be rare. I had no problems the first time but I hadn't created build tags and layouts then, and I'm not sure whether I have something else going on?
Cheers
darkagn
Votes
Translate
Translate
Report
Report
Community Beginner ,
May 24, 2007 May 24, 2007
I was having a similar problem this morning with RoboHelp 6. My project would open, but would immediatly lock up if I tried to do anything. I removed the KB927891 Microsoft update that I had just installed, restarted, and everything works fine now. (I got this idea because it was the only change I had made to my system and because Microsoft updates have caused problems with RoboHelp in the past.) The notes on the Microsoft website indicate that this fix is part one of a two-part solution, so I'm going to wait until the second part is posted in June and try the update again. It could be a fluke that this worked, but thought I would pass the information along.
Audrey
Votes
Translate
Translate
Report
Report
Community Expert ,
When a patch breaks RoboHelp, sometimes you can leave the patch to get the benefit of it and just uninstall and reinstall RoboHelp to make that work again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Jun 21, 2007 Jun 21, 2007
I don't know what to suggest as you are running locally. Do you have a large number of topics in the project, say 5,000 +? How are you opening RH? From an XPJ file in Windows Explorer or by clicking a RH desktop icon?
Do you or someone in your office have Microsoft Access on your PC?
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I too had problems with RoboHelp 6.0. But in my case, I could do any kind of edit and compile the project. However, when I would close my project, RoboHelp would crash displaying a message "RoboHelp encountered a problem....".
After series of troubleshooting calls with Adobe, they asked me to re-create the project as a new one. I had to re-do the TOC, index, and context-sensitive help.
My project was earlier in HTML Help Workshop.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
