2 Replies Latest reply on Apr 22, 2014 1:40 PM by IDOTRhonda
    Do not display 0.0% as answer in calculated field
    IDOTRhonda Level 1
      My field is formated to % and one decimal place and it shows 0.0%.  I would prefer it be blank until both fields are filled in that produce the answer.  I tried to do that with the following calculation and it works until I changed the format to percentage.
      var v1 = +getField("Tons UsedRow1").value;
      var v2 = +getField("Tons RequiredRow1").value;
      if (v1 !== 0 && v2 !==0){
      var result =(v1 / v2);
      event.value = result;
      }else {event.value = '';}
        • 1. Re: Do not display 0.0% as answer in calculated field
          Only a numeric formatted field with nor currency symbol or percentage symbol and display a null value.
          You need to use the built-in formatting functions of Acrobat JS to set the field format as needed.
          I would start with the field being formatted to "None"
          User you custom calculation script.
          Add a custom validation script:
          var nDec = 1; // set the number of decimal places; // number & percent;
          var sepStyle = 0; // thousand separator style; // number & percent;
          var negStyle = 0; // negative style; // number only;
          var currStyle =""; // always null; // number only;
          var strCurrency = ""; // currency symbol; // number only;
          var bCurrencyPrepend = false; // currency prepend; // number only;
          var bPercentPrepend = false; // percentage prepend; // percent only;
          if(event.value == 0 || event.value == "") {
          event.value = "";
          AFNumber_Format(nDec, sepStyle, negStyle, currStyle, strCurrency, bCurrencyPrepend);
          } else {
          AFPercent_Format(nDec, sepStyle, bPercentPrepend);
          • 2. Re: Do not display 0.0% as answer in calculated field
            IDOTRhonda Level 1
            This is perfect! Thank you very much
