0 Replies Latest reply on Jul 10, 2006 5:22 AM by Newsgroup_User
    Re: Highscore for onlinegame
    Level 7
      >I just want to check if I'm thinking right:
      > To make the database I use MySQL (if I get it to work). And then I store
      > the
      > database on a server (Can I use my homecomputer for this - until the game
      > is
      > finished?)
      Yes, you are thinking right.
      You can use your local computer running mySQL. Version 5 should work after
      default installation - use localhost or 127.0.0.1 as your serverhost, and no
      username/password when connecting with MySQL Administrator.
      > Communication between the database and the game is done with netLingo?
      Yes.
      > Communication between the homepage and the database is done with PHP?
      (I normally use asp locally for testing, running on MS IIS server,
      connecting from lingo with postNetText - it works fine.)
      I think you have to run some server service to use PHP locally.
      With the services that most ISP have, it can be a good alternative to use a
      hosted mySQL/PHP, and test it directly on that. You don't have to mess with
      the serversetup, and you normally get a administration area for mySQL - the
      basics are allready taken care of (including easy build of tables and
      connectionstring)
