0 Replies Latest reply on Apr 22, 2014 9:22 AM by jlig
    Single CF Form to Add "x" Number of Voice & Data (Related) Records
    jlig Level 1
      I have an older functioning form that creates a new "Order" record in my "tblCOM" table
      I added two new text type fields called: "HowManyData" & "HowManyVoice" (see image above) and a new field called "pvType"
      Question: How can I adapt my page to handle the following scenario:
      - the user types in a qty of "4" for field "HowManyData"
      - the user types in a qty of "2" for field "HowManyVoice"
      When the Submit button is pressed:
      - the main record is added to "tblCOM" (this is already working fine)
      - four (4) related  "Data" records are added to the "tblProvisioning" table (and pvType is saved w/value of "Data")
      - four (2) related "Voice" records are added to the "tblProvisioning" table (and pvType is saved w/value of "Voice")
      I know this requires something similar to the following:
      <cfquery name="simpleInsert" datasource="mydatasource">
      INSERT INTO tblProvisioning (col1,col2,col3)
      VALUES
      <cfloop from="1" to="5" index="i">
      <cfif i GT 1>,</cfif>
      (#i#,'somename','sometitle')
      </cfloop>
      </cfquery>
      tblCOM table
      - omID (integer auto-increment ID)
      - etc..
      tblProvisioning table
      - pvNum (integer auto-increment ID)
      - pvwoNum (integer foreign key from tblCOM)
      - pvType (varchar for Data or Voice)
      - pvDate (current_timestamp)
