1 Reply Latest reply on Apr 22, 2014 10:11 PM by George_Johnson
    Can't get leading 0's to begin before a certain field with max characters allowed?
    hpdouet
      I use several text fieds that populate into another text field used as a barcode with a limit of 44 characters.  The var AcctNO has a limit of 10 characters (some could be leading 0's and shouldn't be removed).  The Var BoxNO has a limit of 10 characters (some could be leading 0's and shouldn't be removed). The Var SSN1 has a limit of 9 characters (no leading 0's are removed).The Var DOCTYPECODE has a limit of 5 characters. The Var DOCDATE has a limit of 10 charachers but the calculation script removes the "/" "/" (leading 0's are not removed).
      This is the custom calculation script I am using:
      // Custom calculation script
      (function () {
      // Get the field values, as strings
      var AcctNO = getField("AcctNO").valueAsString;
      var BoxNO = getField("BoxNO").valueAsString;
      var SSN1 = getField("SSN1").valueAsString;
      var DOCTYPECODE = getField("DOCTYPECODE").valueAsString;
      var DOCDATE = getField("DOCDATE").valueAsString;
      var PageNO = getField("PageNO").valueAsString;
      // Set this field value by concatenating the field values
      event.value = (AcctNO + SSN1+ DOCTYPECODE + DOCDATE + PageNO + BoxNO).replace("/","", "g");
      // Custom Format script
      (function () {
      // Get the character limit for this field
      var max_chars = event.target.charLimit;
      // Define the pad character to use
      var pad_char = "0";
      // If the field is not blank and there is a character limit, pad value with leading zeroes
      if (event.value && max_chars) {
      event.value = (new Array(max_chars + 1).join(pad_char) + event.value).slice(-max_chars);
      event.value = "*" + event.value + "*";
      If all fields are keyed correctly then the barcode should read like this:
      *0123456789222222222K702504232013010000001234*
      But it is reading like this instead:
      *00000001234567891234222222222K70250424201401*
      What do I need to change in order for this to work correctly?
