3 Replies Latest reply on Apr 28, 2014 12:32 AM by Patook2132
    HTML extension CEPEngine process stdout and stderr usage
    Patook2132
      Hi all,
      I'm trying to use CEPEngine to start a ncftpput process on windows.
      I need to listen what ncftpput output on stdout to make a sort of progress bar.
      Unfortunatly cep.process.stdout callback seems to receive only the first line of output (LibNcFTP 3.2.5 (January 17, 2011) compiled for Windows)
      This is my code :
                  var exe=extpath+"\\resources\\win\\ncftpput.exe";
                  var result=cep.process.createProcess(exe,"-Z","-d","stdout","-P",port,"-R",ip,"/",filepath);
                  if (result.err==cep.fs.NO_ERROR) {
                      var pid = result.data;
                      cep.process.stdout(pid,function(e){
                          console.log(e);//receive only the first line in stdout ?
                      cep.process.stderr(pid,function(e){
                          console.log(e); //receive nothing ?
                      cep.process.onquit(pid,function(){
                          console.log("quit");
      Is it a known bug or there's something I'm doing wrong ?
      (That kind of thing worked with previous AS extensions)
        • 1. Re: HTML extension CEPEngine process stdout and stderr usage
          weiguo@adobe.com Adobe Employee
          Limitation of cep.process.stdout/stderr
          There is an known limitation of cep.process.stdout/stderr which is targeting to capture one time of stdout/stderr output.
          For applications that has not integrated CEP 5, there are two workarounds are suggested as the following.
          1. 1. Embed cep.process.stdout/stderr, like below
          2. window.cep.process.stdout(proc.data,function(line){
              console.log(line);
              window.cep.process.stdout(proc.data,function(line2){
                  console.log(line2);
                  window.cep.process.stdout(proc.data,function(line3){
                      console.log(line3);
          1. 2. Join all stdout output as one, like below
          var str1 = 'abcdef';
          var str2 = '12345';
          var str3 = 'gghhtt';
          1. console.log(str1 + str2 + str3);
          Since CEP5, NodeJS is integrated into CEP runtime and users could invoke the standard APIs of NodeJS in extension directly. For applications that has integrated CEP 5, refer to http://nodejs.org/api/process.html for how to use the global process object in NodeJS.
          • 2. Re: HTML extension CEPEngine process stdout and stderr usage
            jun xia Adobe Employee
            Yes, like Guo said, there is a limitation of window.cep.process.stdout/stderr. But you could call it recursively like below to get all the stdout.
            function getSTDOutput()
                    console.log("getSTDOutput");
                    window.cep.process.stdout(pid, function(output) {
                                                console.log(output);
                                                //your code is here
                    var result = window.cep.process.isRunning(pid);
                    if (result.data == true)
                        setTimeout(getSTDOutput, 1000);
            Could you have a try and let us know if this resolve your issue?
            Jun
            • 3. Re: HTML extension CEPEngine process stdout and stderr usage
              Patook2132 Level 1
              Yes, it works, thanks for your responses !
              I made some litlle change from xia solution because i need to parse all lines individually :
                  function getSTDOutput(pid){
                          var lines=output.split(('\n'));
                          for (var i=0;i<lines.length;i++){
                              console.log(lines[i]);
                          var result = cep.process.isRunning(pid);
                          if (result.data == true){
                              setTimeout(function(){getSTDOutput(pid)}, 0);
              I can go further in my indesign extension migration
