5 Replies Latest reply on May 21, 2007 9:11 PM by nITiNkIlLeRmEeRuT
    XML wont load
    mr.nazarko
      hello,
      im using this great tutorial from gotoandlean.com
      but have run into some problems
      im trying to load jpg's into a flash with xml, using the following code
      var x:XML = new XML ();
      x.ignoreWhite = true;
      var urls:Array = new Array();
      var captions:Array = new Array();
      var w:Array = new Array();
      var h:Array = new Array();
      var WhoIsOn:Number;
      x.onLoad = function() {
      var photos:Array = this.firstChild.childNodes;
      for (i=0;i<photos.length;i++) {
      urls.push(photos .attributes,url);
      captions.push(photos
      .attributes,caption);
      holder.loadMovie(urls[0]);
      caption.text = captions[0];
      whoIsOn = 0;
      x.load(" http://www.antonnazarko.com/DAVE/photoLIST.xml");
      previous.onRelease = function (){
      if (whoIsOn > 0){
      whoIsOn--;
      holder.loadMovie(urls[whoIsOn]);
      caption.text = captions[whoIsOn];
      but i always get this prompt
      Error opening URL 'file:///C|/Documents%20and%20Settings/anton/Desktop/DAVEG/[type Object]'
      -- could someone double check thie code for me ?
      not sure why it doesnt work.
      thanks,
      anton
        • 1. Re: XML wont load
          joeschmoesdf Level 1
          use a relitive location for the file such as
          x.load("DAVE/photoLIST.xml");
          • 2. Re: XML wont load
            Level 7
            are u using the url of somebody elses domain.
            if not give relative path to xml.
            "mr.nazarko" <webforumsuser@macromedia.com> wrote in message
            news:f2raih$i0p$1@forums.macromedia.com...
            > hello,
            > var WhoIsOn:Number;
            > whoIsOn = 0;
            > if (whoIsOn > 0){
            > whoIsOn--;
            > Error opening URL
            > thanks,
            > anton
            • 3. Re: XML wont load
              mr.nazarko Level 1
              hey thanks for the reply,
              tried to use relative path,
              x.load("photoLIST.xml"); -- should work? all files are in a local folder!
              also tried it online with two different servers,
              but still wont work,
              still get this prompt
              Error opening URL
              why is it looking locally when ive directed it to an absolute path?
              could this old tutorial im using be incompatible with cs3?
              any help is appreciated,
              thanks again,
              anton
              • 4. Re: XML wont load
                mr.nazarko Level 1
                can someone check if my xml is wrong?
                what is a type Object?
                the my xml loaded variable caption comes up as "type Object"
                instead of the real caption.
                thanks again,
                anton
                • 5. XML wont load
                  nITiNkIlLeRmEeRuT Level 1
                  Try this
