4 Replies Latest reply on May 22, 2007 5:53 PM by kglad
    loadMovie and target
      I've never used the loadMovie function before so I'm really not sure what I'm doing wrong. I have a button. When you push the button, an .swf file (or .jpg, I need to be able to load both into different clips with different buttons and the problem is the same) should load into a rectangular target area. The target area is a solid black rectangle movie clip. Both the .swf and .jpg file are in the same folder as my flash file. When I press the button nothing happens, I don't even get an error message when I go to test it. The strangest thing is that when I try and use the same button with the same on handler to load the same .swf file into a layer (layer 1, if it matters) everything works perfectly. Thank you, my script is posted below, nice and short but it still doesn't work.
