1 Reply Latest reply on May 21, 2007 10:16 AM by dhogue94
    group two or more objects
    123polis123 Level 1
      when I group two or more objects in two or more layers , final object in what layer goes ?
        • 1. Re: group two or more objects
          dhogue94
          It appears that the grouped objects will be placed in the layer that is higher in the stack. If you later ungroup the objects, both objects will remain in the higher layer - they will not return to their original layers.
          For example,
          Object A is in Layer 1 and Object B is in Layer 3. Select and group Objects A and B, and the grouped objects will be placed in Layer 3 (which is higher in the stack.) If you then ungroup these objects, both of them will be placed in Layer 3.
