• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Convert Arbortext XML files to RoboHelp
Guest
Apr 23, 2014 Apr 23, 2014
We are converting XML files from Arbortext to RoboHelp. Does anyone know how to conver the files? We would like to import or convert the files and remove the XML code Arbortext automatically adds to the files.
Thanks! Sandy
Views
868
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
I am not familiar with Arbortext's XML, but why do you want to remove it? You can import XML files into RoboHelp, so if it imports correctly and you can generate your output, why bother tidying the XML?
Votes
Translate
Translate
Report
Report
New Here ,
Arbortext XML isn't different to any other XML document format. It will usually be in a DITA, Docbook or custom XML schema. Some of those types may be easier to import to RoboHelp than others. What is also worth mentioning is that your Arbortext may already be able to produce HTML and/or HTML Help formats. These may help the conversion process?
Votes
Translate
Translate
Report
Report
Community Beginner ,
Apr 24, 2014 Apr 24, 2014
Are you talking about the XML comment Arbortext puts into the top of the document or the Processing Instructions?
If the first, Arbortext does insert an XML Comment at the top of the file. XML Comments do not affect the XML content and this should not affect your processing. For example, if you import DITA files created in Arbortext into TCS 4 or 5, they open and process just fine. I've had no problems importing Arbortext XML into TCS4 and exporting files via RoboHelp.
If you're talking about the processing instructions, they are unnecessary to retain and very easy to remove via a setting in Tools Preferences. The instructions to turn off Processing Instructions are here: http://blog.single-sourcing.com/2010/08/pesky-pis/
Votes
Translate
Translate
Report
Report
Guest
Thanks for all the help!
We would rather use HTML instead of XML. Also, the XML tags are custom and we would rather move away from the custom tags.
Votes
Translate
Translate
Report
Report
Then your best bet is MadCap Flare. It's HTML start to finish.
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 26, 2014 Apr 26, 2014
LATEST
@Elizabeth Rh is also HTML. I am not seeing how Flare is going to help this poster, especially as they already have Rh.
@petergrainge
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
