12 Replies Latest reply on Apr 24, 2014 12:44 PM by Chris Cox
    Noob question about HDR images
    ShinyDawn999
      hi everybody! i am reading this book about photoshop hoping to understand a lot more than i already know about pixels and colors and image dinamics and such..i got to the chapter about HDR images and here's what i dont get. as i understand, given a HDR image it has 32 bit depth meaning its file contains much more information about contrast and brightness than any existing monitor can output, so when u open it in photoshop u will never see its true quality. my question is( and i admit it may seem pointless to some, but i am committed to understand the cause and purpose), when converting it to 8 or 16 bit depth this window pops up asking me to tweak gamma, exposure, shadows and highlights, etc., but why is this linked to the conversion process? why not simply convert it, maintain the same appearance as before and then if needed manually adjust using all the image controls from the photoshop menus? i have CS6, if that matters.
        • 1. Re: Noob question about HDR images
          Level 7
          Because you generally don't want to convert it as-is, you want it toned into a range that LDR images (8 and 16 bit/channel) can handle.
          And because after you convert from 32 bit/channel down to 8 or 16, you've lost a lot of data that you can't recover.
          • 2. Re: Noob question about HDR images
            ShinyDawn999 Level 1
            i tested that if i convert to 8 bit using exposure and gamma method with default settings, the appearance of the hdr image remains the same, it seems that no color data was lost there(this relating to the second sentence of your post). to me the modifying of all those lighting settings is something u choose no matter what type of picture u have in front of you, doesnt look like needed for hdr ones. i may be very much mistaking, but it's because i still cant make sense of it.
            • 3. Re: Noob question about HDR images
              Level 7
              Yes, you are mistaken.
              HDR is High Dynamic Range. You can't see the whole range on your display, or in an 8 or 16 bit image.  LDR images represent a range of 0 to 1.  HDR represents a range of -infinity to +infinity.
              When you converted to 8 bit, you lost the data brighter than white, and darker than a few levels above black.
              You also have to remember that to make an HDR image, you need many LDR images made at different exposures, or a high precision 3D rendering of a scene. You can't just convert an 8 or 16 bit image to 32 bit/channel and instantly have high dynamic range data.
              • 4. Re: Noob question about HDR images
                bare with me if you please and i am not bugging you too much:)
                "When you converted to 8 bit, you lost the data brighter than white, and darker than a few levels above black."
                i thought i cannot see that data anyway, due to the limitation of the monitor. so what difference does it make?
                • 5. Re: Noob question about HDR images
                  Level 7
                  Just because you couldn't see the data on your monitor does not mean that the data does not exist, or shouldn't be visible when the image is toned correctly.
                  Many of Ansel Adams's negatives would have had blown out white areas when printed - but he spent time tweaking the exposure, dodging and burning to make more detail visible.  That's the same sort of thing you are doing with HDR toning.
                  • 6. Re: Noob question about HDR images
                    ok, one more thing i want to ask. is it safe to say that normally viewing of a hdr in.. say acdsee wouldnt reveal its true quality, but in photoshop, with necessary adjusting, all that "hidden" data becomes available? so to speak, only in photoshop?
                    • 7. Re: Noob question about HDR images
                      Level 7
                      Unless you do some toning to make the HDR data visible in LDR, or use a specialized HDR display, you can't see all the HDR data at one time.  But there are other applications that also work with HDR data, and can do toning or at least change the exposure in realtime.
                      • 8. Re: Noob question about HDR images
                        DrStrik9 Level 4
                        I don't know if this will help, but I've heard about HDR monitors (still very expensive), which supposedly very accurately display the HDR values. If you hang one on the wall in your house, people might think it's a window, since it is literally a source of light, in the same way a window to the outside world is.
                        Possibly the most surprising use of HDR imagery is in 3D apps where global illumination models are used. HDR imagery literally is the only source of light for these images. There are no lights in the scene, only HDR imagery. This is because of the great dynamic range of HDR.
                        A more practical (to me) use of HDR is when resurrecting antique images. If you scan multiple exposures from old prints, then create HDR, sculpting values in 16-bit becomes a very powerful tool, only due to the HDR value range.
                        Photoshop, although it can edit very well in 16-bit, can only show 8-bit representations of HDR imagery, since almost all monitors are 8-bits per channel. Because of the monitors, we can only see a small part of what is actually present in the HDR file.
                        I've never done it, but I imagine that if we all had HDR monitors, we'd need to wear protective glasses (like you wear driving in your car when the sun is out) most of the time to do our work.  :+)
                        • 9. Re: Noob question about HDR images
                          Level 7
                          Yeah, "white" on the HDR displays kinda demands sunglasses.
                          • 10. Re: Noob question about HDR images
                            as u said, when converting hdr to 8 or 16 bit, information is lost. then how can i reveal back information(via tonal mapping) if it has been lost in the process? cos adjusting gamma for example isnt adding back information to each pixel, is it? its still 8 or 16 bit.. it sounds to me like "do all this adjusting and u will see the 8 bit version as good as the hdr would show on a hdr display device, whatever that may be, but by definition of the hdr u simply cant", thats why im so confused.
                            thanks for the time and patience, if im pushing it too far, just feel free to stop answering, i will totally understand
                            • 11. Re: Noob question about HDR images
                              DrStrik9 Level 4
                              Once you reduce the bit-depth from an HDR image, the values are still there, there just aren't as many of them. Your 8-bit monitor will still show all the values that it can show you, but if the image is 8-bit, what you see on your mopnitor is [all] the values there are in the image.
                              I find the best strategy is to retain the 32-bit image for any potential future changes, reduce it to 16-bit for any post-HDR retouch and adjustment and retain that version as well. Then for emailing clients or putting images on the web, an 8-bit conversion (as in a jpeg format) works perfectly. And you still have the higher bit-depth versions in case something needs to be adjusted in the future.
                              • 12. Re: Noob question about HDR images
                                Level 7
                                When you do the toning, you are compressing the larger HDR tonal range into the smaller LDR tonal range.
                                You aren't adding anything back, you are compressing the range to make more things visible before finalizing the conversion to an LDR image.  And no, LDR images are never as good as HDR images.
