5 Replies Latest reply on Apr 24, 2014 5:57 AM by cathykka
    Loop Page Style Sheet to set file name.
    cathykka
      I am exporting pages to jpgs and pngs using a script that pulls the name from an applied style sheet.
      http://forums.adobe.com/message/5913479#5913479
      the above works perfectly if I only want to specify one style sheet as the file name.
      the challenge may need to use different style sheets on each page to create the name.
      I am not sure how to loop through each page and grab the style in play.
      or if I need to loop at all.
      This is where I am...
      function MakePNGfile()
           for(var myCounter = 0; myCounter < myDoc.pages.length; myCounter++)
                if (myDoc.pages.item(myCounter).appliedSection.name != "")
                     myDoc.pages.item(myCounter).appliedSection.name = "";
            var myStyle1 = "sheetlabel-text";
            var myStyle2 = "sheetlabel-text-2";
            var myParagraphs = myDoc.pages.item(0).textFrames.item(0).parentStory.paragraphs;
                var myPageName = myDoc.pages.item(myCounter).name;
            var myPNGPrefix = "";
           for( i = 0; i < myParagraphs.length; i++)
               var paragraph = myParagraphs.item(i);
      if (paragraph = myStyle1)
          (myPNGPrefix = getParagraphContent(myDoc.paragraphStyles.item("sheetlabel-text"),  myDoc.pages.item(myCounter))+ '-0' + myPageName)
      else
          (myPNGPrefix = getParagraphContent(myDoc.paragraphStyles.item("sheetlabel-text-2"),  myDoc.pages.item(myCounter))+ '-0' + myPageName)
      Thanks for your help!
        • 1. Re: Loop Page Style Sheet to set file name.
          Kai Rübsamen Level 4
          Some questions:
          1. Do you have only those 2 paragraph styles?
          2. What should happen, if both paragraph styles are on the same page > which style should create the filename?
          3. Your mentioned script insert always a "0" in front of the pages name > what should happen, if you have more than 9 pages?
          4. What should happen, if there is no found of one of the styles on a page?
          Find attached my current version of the script. The script is not perfect at the moment, because the above questions are not clear to me. Nervertheless it should produce a result ;-)
          main ();
          function main() {
          var curDoc = app.activeDocument;
          // Array of paragraph Style names
          var paraStyleNames = ["h1", "h2"]; // insert here your para names !
          var missingParaStyles = [];
          // check, if the styles are valid
          for ( var p = 0; p < paraStyleNames.length; p++ ) {
              var curName = paraStyleNames[p];
              // if the style is missing, push it to the array
              if ( !curDoc.paragraphStyles.itemByName(curName).isValid ) {
                  missingParaStyles.push( curName );
          // if some styles are missing, give an alert
          var nMiss = missingParaStyles.length;
          if ( nMiss > 0 ) {
              var display = missingParaStyles.join( "\r" );
              alert ( "Missing para(s):\r" + display );
              exit();
          // loop through pages
          for ( var i = 0; i < curDoc.pages.length; i++ ) {
              // the current page
              var curPage = curDoc.pages[i];
              // the current page name
              var pName = curPage.name;
              var allPageParas = curPage.textFrames.everyItem().paragraphs.everyItem().getElements();
              for ( var p = 0; p < allPageParas.length; p++ ) {
                  var curPara = allPageParas[p];
                  if ( curPara.appliedParagraphStyle.name == paraStyleNames[0] || curPara.appliedParagraphStyle.name == paraStyleNames[1] ) {
                      var paraContents = curPara.contents;
                      var paraString = "-" + paraContents.replace( /\s+$/ , "" ).replace( /\s+/g , "-" ).toLowerCase();
                      break;
                  } // end if
              } // end for > allPageParas
              //~ var folderPath = "~/-client/JOYS - Just Organize Your Stuff/-Art/-art-book-kindle/";
              var folderPath = Folder.desktop;
              var filePath = folderPath + "/" + curDoc.name.replace(/\.indd$/,"") + "-0" + pName + paraString + ".jpg";
              var myFile = File( filePath );
              with ( app.jpegExportPreferences) {
                  jpegQuality = JPEGOptionsQuality.high; // low medium high maximum
                  exportResolution = 72;
                  jpegExportRange = ExportRangeOrAllPages.exportRange;
                  pageString = pName;
              curDoc.exportFile( ExportFormat.jpg, myFile, false );
            } // end for > pages
          } // end main
          • 2. Re: Loop Page Style Sheet to set file name.
            cathykka Level 1
            Thanks Kai.
            no. there are many more. but depending on the file I will use different ones.
            both will not be on the same page
            I would just like a 0 in front of the single page numbers 1-9 so the files are organized by page number
            Not really important. Null is fine.
            Trying you script now. Again... thanks so much.
            • 3. Re: Loop Page Style Sheet to set file name.
              cathykka Level 1
              Kai. This worked perfectly for my needs. Removing the leading zero before the multidigit page numbers would be awesome... but this is exactly what I needed. Much appreciation to you.
              • 4. Re: Loop Page Style Sheet to set file name.
                Good to hear .
                Find attached the next version. You can now insert in 'paraStyleNames' as many style names as you want. The script will check from left to right, if there is one found on the page. If this is true, the script will ignore the other styles.
                Removing leading zero should work now.
                Maybe one problem: If one page contains no style, this page will be exported nevertheless with it’s correct page number, but with the founded text of the previous page. If this can never happen, we are done and you should mark the answer as correct. If this is a real problem for you, please let me know, what should happen in this case and I will try to fix that too.
                // Export pages as JPG with additional info by Kai Rübsamen
                // http://forums.adobe.com/message/6326425#6326425
                main ();
                function main() {
                if ( nMiss > 0 ) {
                    exit();
                // loop through all pages
                    // the current page
                    // the current pages name
                    // controls the loop
                    var controller = true;
                    // all paragraphs on the current page
                    // loop through all paragraphs and check, if one has the para style applied
                        if ( !controller ) break;
                        // the current para
                        // loop through the styles
                        for ( var n = 0; n < paraStyleNames.length; n++ ) {
                            if ( curPara.appliedParagraphStyle.name == paraStyleNames[n] ) {
                                controller = false;
                                break;
                            } // end if
                        } // end for paraStyleNames
                    } // end for allPageParas
                    if ( pName < 10 ) {
                        var appendix = "-0" + pName + paraString;
                    else {
                        var appendix = "-" + pName + paraString;
                    var filePath = folderPath + "/" + curDoc.name.replace(/\.indd$/,"") + appendix + ".jpg";
                    with ( app.jpegExportPreferences ) {
                        pageString = pName;
                  } // end for pages
                } // end main
                –Kai
                • 5. Re: Loop Page Style Sheet to set file name.
                  cathykka Level 1
                  Kai you're a blessing and I am grateful! Worked perfectly.
