5 Replies Latest reply on Apr 28, 2014 9:50 AM by SXM132
    Key up Audio Stop
    SXM132
      I'm making an interactive piano tutorial, and I have a strings scale attached to the key down of several keys. Here is an example of one key down;
      if (e.which == 65) {  //A
                var getShot = sym.getSymbol("soundtestA").getSymbol("Asound");
                getShot.play("A");
      It works fine, but upon lift it keeps playing through - making the notes slow and delayed.
      I'm not too code savy. How can I link the key up to either pause or stop the sound bite?
        • 1. Re: Key up Audio Stop
          Zaxist Level 4
          you can do it this way :
          //in Stage > compositionReady
          music = sym.$("MusicFileName")[0];
          //in keydown
                    music.play();
          //in keyup
                    music.pause();
                    music.currentTime = 0;
          Hope this can help you
          if you had any question let me know ..
          regards
          Zaxist
          • 2. Re: Key up Audio Stop
            SXM132 Level 1
            Can you define what you mean by "MusicFileName"?
            Is it the symbol it's in or the actual .WAV file name?
            Either way, I've tried using both but neither work =/ Good guess though
            • 3. Re: Key up Audio Stop
              Zaxist Level 4
              in your Project as i can see you named it Asound
              so your music line should be like this
              music = sym.getSymbol("soundtestA").$("Asound")[0];
              regards
              Zaxist
              • 4. Re: Key up Audio Stop
                Sudeshnasarkar27 Adobe Employee
                Hi ,
                I am sharing a sample for playing audio as long as say "a" is pressed and on keyup it would stop the audio.
                Basically , on my stage keyup the code is -
                if (e.which == 65)
                          sym.$("mysong")[0].muted = true;
                          console.log("Keyup for A");
                          sym.$("mysong")[0].stop();
                and on stage keydown it is -
                if (e.which == 65)
                          sym.$("mysong")[0].muted = false;
                          console.log("Keydown for A");
                          // Play an audio track
                          sym.$("mysong")[0].currentTime = 0;
                          sym.$("mysong")[0].play();
                where "mysong" is the song element.
                Let me know if that solves your problem.
                Thanks and Regards,
                Sudeshna Sarkar
                • 5. Re: Key up Audio Stop
                  SXM132 Level 1
                  As far as functionality goes this solves the problem. It make a new one, however.
                  After pressing key down for a while the audio begins to jitter horribly. Can this be fixed by adjusting the code's timing cues?
