3 Replies Latest reply on Apr 25, 2014 2:29 AM by Mylenium
    Render trouble
    gordonzinga
      Well i have a really time consuming issue. I'm trying to currently render a project which has taken me atleast two days to do so. And is very annoying. the project literarly has 10 particles and a backround and has one effect only, (CC particle world). it glides through very smoothly at the start and when it gets to the end it renders about 1 frame every 20 seconds and theres about 10000 frames from what i know.   Sorry if the image is too small I'm not realy sure if theres a way to zoom into images here since i'm new, thanks
      _______________________
      My Main System Specs:
      4GB DDR3
      INTEL Core i3
      INTEL graphics 4000
        • 1. Re: Render trouble
          And what exactly? 10000 frames for a single shot is a lot and your system isn't particularly beefy. You simply bring it to its edge by exhausting all resources. Really not sure what magic button you are looking for.
          Mylenium
          • 2. Re: Render trouble
            gordonzinga Level 1
            But i've rendered projects as big as this before and it's rendered much faster.. so it's not got to do with my resources and besides, a large percentage of my resources are free when it's rendering.
            • 3. Re: Render trouble
              Then you need to explain in more detail what settings you used, what the comp actually contains and so on. Your initial post isn't particulalrly descriptive and even a single effect could be causing such a behavior. Perhaps your CC Particles simply accumulate and while there may be only ten visible ones, there could actualyl be hundreds or thousands need to be calculated for every frame...
              Mylenium
