9 Replies Latest reply on Jan 13, 2015 9:19 AM by Gianni Gallo
    Radial blur filter
    max_o_max
      After last Photoshop update the radial blur filter inteface seems corrupted
      Do you have any suggestion?
        • 1. Re: Radial blur filter
          c.pfaffenbichler Level 9
          I can’t reproduce that with Photoshop 14.2.1 on Mac OS 10.8.5.
          Please read these and proceed accordingly:
          http://forums.adobe.com/docs/DOC-2325
          http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-mos t-issues.html
          • 2. Re: Radial blur filter
            max_o_max Level 1
            I'm running Mac OS 10.9.2 and Photoshop 14.2.1
            • 3. Re: Radial blur filter
              Does turning off »Use Graphics Processor« in the Performance Preferences and restarting Photoshop have any bearing on the issue?
              • 5. Re: Radial blur filter
                Level 7
                My guess would be corrupt font information from the OS (so that the auto-layout fails due to bad font sizes reported by the OS).
                Try this page for help: http://helpx.adobe.com/photoshop/kb/troubleshoot-fonts-photoshop-cs5.html
                • 6. Re: Radial blur filter
                  max_o_max Level 1
                  I have done everything you suggested. Without success...
                  When I run the font test I had this report:
                  Photoshop CS6 Font Test
                  Start Time:          Fri Apr 25 2014 22:14:53 GMT+0200
                  End Time:          Fri Apr 25 2014 22:22:38 GMT+0200
                  Execution Time:          464.748 seconds
                  The number of fonts installed:          803
                  The number of fonts tested:          803
                  The number of fonts passed:          803
                  The number of fonts failed:          0
                  Test Result: PASS
                  Clear Font Cache: ON
                  .......... OMISSIS..........
                  System Information
                  Adobe Photoshop versione: 14.2.1 (14.2.1 20140207.r.570 2014/02/07:23:00:00) x64
                  Sistema operativo: Mac OS 10.9.2
                  Architettura di sistema: Famiglia CPU Intel:6, Modello:60, Stepping:3 con MMX, Intero SSE, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, HyperThreading
                  Conteggio processore fisico: 4
                  Conteggio processore logico: 8
                  Velocità processore: 3500 MHz
                  Memoria incorporata: 16384 MB
                  Memoria disponibile: 10104 MB
                  Memoria disponibile per Photoshop: 15246 MB
                  Memoria usata da Photoshop: 70 %
                  Dimensioni porzioni immagine: 1024 K
                  Livelli cache immagine: 4
                  Anteprima font: Disattivato
                  Composizione testo: Latino
                  Monitor: 1
                  Monitor principale
                  Visualizza limiti: alto= 0, sinistra= 0, basso= 1440, destra= 2560
                  Monitor: 2
                  Visualizza limiti: alto= 0, sinistra= 2560, basso= 1440, destra= 5120
                  Disegno OpenGL: attivato.
                  OpenGL - Consenti GPU precedenti: Non rilevato.
                  OpenGL - Modalità disegno: Avanzata
                  OpenGL - Consenti modalità normale: True.
                  OpenGL - Consenti modalità avanzata: True.
                  AIFCoreInitialized=1
                  AIFOGLInitialized=1
                  OGLContextCreated=1
                  NumGPUs=1
                  gpu[0].OGLVersion="2.1"
                  gpu[0].MemoryMB=4096
                  gpu[0].RectTextureSize=16384
                  gpu[0].Renderer="NVIDIA GeForce GTX 780M OpenGL Engine"
                  gpu[0].RendererID=16918308
                  gpu[0].Vendor="NVIDIA Corporation"
                  gpu[0].VendorID=4318
                  gpu[0].HasNPOTSupport=1
                  gpu[0].CompileProgramGLSL=1
                  gpu[0].TestFrameBuffer=1
                  gpu[0].OCLPresent=1
                  gpu[0].OCLVersion="1.2 (Dec  8 2013 21:07:05)"
                  gpu[0].CUDASupported=0
                  gpu[0].OCLBandwidth=3.37648e+10
                  gpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.20"
                  gpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[16384]
                  gpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                  gpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[16]
                  gpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
                  gpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
                  gpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                  gpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                  gpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[2048]
                  gpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                  gpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                  gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                  gpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                  gpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                  Tipo di licenza: Iscrizione
                  Numero di serie: 91190134802272675259
                  Cartella applicazione: /Applications/Adobe Photoshop CC/
                  La memoria virtuale di Photoshop dispone di I/O asincrono attivato
                  Volumi di memoria virtuale:
                    Scratch, 29,4 GB, 27,9 GB disponibili
                  Cartella plug-in richiesti: /Applications/Adobe Photoshop CC/Adobe Photoshop CC.app/Contents/Required/Plug-Ins/
                  Cartella plug-in principali: /Applications/Adobe Photoshop CC/Plug-ins/
                  Componenti installati:
                     adbeape.framework   adbeape   3.4.0.29366   0.1160850
                     AdbeScriptUIFlex.framework   AdbeScriptUIFlex   6.3.2.31983   79.546835
                     adobe_caps.framework   adobe_caps   7.0.0.21   1.248010
                     AdobeACE.framework   AdobeACE   2.20.02.31977   79.548223
                     AdobeAGM.framework   AdobeAGM   4.30.29.31977   79.548223
                     AdobeAXE8SharedExpat.framework   AdobeAXE8SharedExpat   3.7.101.18636   66.26830
                     AdobeAXEDOMCore.framework   AdobeAXEDOMCore   3.7.101.18636   66.26830
                     AdobeBIB.framework   AdobeBIB   1.2.03.31977   79.548223
                     AdobeBIBUtils.framework   AdobeBIBUtils   1.1.01   79.548223
                     AdobeCoolType.framework   AdobeCoolType   5.15.00.31977   79.548223
                     AdobeCrashReporter.framework   AdobeCrashReporter   7.0.1
                     AdobeExtendScript.framework   AdobeExtendScript   4.5.5.31983   79.546835
                     AdobeJP2K.framework   AdobeJP2K   1.2.2.31977   79.248139
                     AdobeLinguistic.framework      19061
                     AdobeMPS.framework   AdobeMPS   5.8.1.31977   79.535029
                     AdobeOwl.framework   AdobeOwl   5.0.24   79.547804
                     AdobePDFL.framework   AdobePDFL   11.0.0.31977   79.508720
                     AdobePDFSettings.framework   AdobePDFSettings   1.4
                     AdobePIP.framework   AdobePIP   7.0.0.1786
                     AdobeScCore.framework   AdobeScCore   4.5.5.31983   79.546835
                     AdobeUpdater.framework   AdobeUpdater   6.0.0.1452   "52.338651"
                     AdobeXMP.framework   AdobeXMPCore   79.154911   79.154911
                     AdobeXMPFiles.framework   AdobeXMPFiles   79.154911   79.154911
                     AdobeXMPScript.framework   AdobeXMPScript   79.154911   79.154911
                     ahclient.framework   ahclient   1.8.0.31
                     aif_core.framework   AdobeAIF   5.0.00   79.534508
                     aif_ocl.framework   AdobeAIF   5.0.00   79.534508
                     aif_ogl.framework   AdobeAIF   5.0.00   79.534508
                     AlignmentLib.framework   xcode   Copyright © 2013 Adobe Systems Incorporated
                     amtlib.framework   amtlib   7.0.0.249
                     boost_date_time.framework   boost_date_time   7.0.0.0
                     boost_signals.framework   boost_signals   7.0.0.0
                     boost_system.framework   boost_system   7.0.0.0
                     boost_threads.framework   boost_threads   7.0.0.0
                     Cg.framework   NVIDIA Cg
                     CIT.framework   CIT   2.1.6.30929   151865
                     CITThreading.framework   CITThreading   2.1.6.30929   151865
                     dvaaudiodevice.framework   dvaaudiodevice   7.0.0.0
                     dvacore.framework   dvacore   7.0.0.0
                     dvamarshal.framework   dvamarshal   7.0.0.0
                     dvamediatypes.framework   dvamediatypes   7.0.0.0
                     dvaplayer.framework   dvaplayer   7.0.0.0
                     dvatransport.framework   dvatransport   7.0.0.0
                     dvaunittesting.framework   dvaunittesting   7.0.0.0
                     dynamiclink.framework   dynamiclink   7.0.0.0
                     FileInfo.framework   FileInfo   79.154511   79.154511
                     filter_graph.framework   AdobeAIF   5.0.00   79.534508
                     ICUConverter.framework   ICUConverter   3.61   "gtlib_3.0" "." "16615"
                     ICUData.framework   ICUData   3.61   "gtlib_3.0" "." "16615"
                     LogSession.framework   LogSession   2.1.2.1785
                     mediacoreif.framework   mediacoreif   7.0.0.0
                     patchmatch.framework   patchmatch   1.2.00.31977   79.542390
                     PlugPlugOwl.framework   PlugPlugOwl   4.2.0.36
                     UpdaterNotifications.framework   UpdaterNotifications   7.0.1.102   "7.0.1.102"
                     WRServices.framework
                  Plug-in richiesti:
                     3D Studio 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Affresco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Applica texture 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Asimmetria 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Bagliore diffuso 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Bassorilievo 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Bordi brillanti 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Camera Raw 8.4 (199), Copyright © 2014 Adobe Systems Incorporated - dal file “Camera Raw.plugin”
                     Carta da lettere 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Cineon 14.2.1 x001  ©2002-2014 Adobe Systems Incorporated - dal file “Cineon.plugin”
                     Collada DAE 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Colore mezzetinte 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Colori NTSC  14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “NTSC Colors.plugin”
                     CompuServe GIF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Contorni accentuati 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Contorni con inchiostro 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Contorni poster 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Contorni strappati 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Conté Crayon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Coordinate polari 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Core misurazione 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “MeasurementCore.plugin”
                     Correzione obiettivo 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - dal file “Lens Correct.plugin”
                     Cristallizza 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Curtosi 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Deforma 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Deviazione standard 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Dicom 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “dicom.plugin”
                     Dipinto a olio 14.2, Copyright © 2014 Adobe Systems Incorporated - dal file “Oil Paint.plugin”
                     Distorsione curvilinea 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Eazel Acquire 14.2.1 x001  ©1997-2014 Adobe Systems Incorporated - dal file “EazelAcquire.plugin”
                     Effetto acquerello 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto carboncino 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto carta bagnata 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto cromatura 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto fotocopia 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto increspatura 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Effetto incrinatura 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto intonaco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto onda 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Effetto pennellate 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto punti 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Effetto retinatura 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto ritaglio 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto sfera 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Effetto sfumino 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto spatola 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto spirale 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Effetto spugna 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Effetto vento 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Entropia 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Estrusione 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Fibre 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Filtro Camera Raw 8.4 (199), Copyright © 2014 Adobe Systems Incorporated - dal file “Camera Raw.plugin”
                     Filtro Pacchetto immagini 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “ChannelPort.plugin”
                     Filtro ritaglia e raddrizza foto 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Flash 3D 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Fluidifica 14.2, Copyright © 2001-2014 Adobe Systems Incorporated - dal file “Liquify.plugin”
                     Formato file bitmap 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Formato IFF 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Formato PNG 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Formato Targa 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Fuoco prospettico 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “VanishingPoint.plugin”
                     Galleria filtri 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Gessetto e carboncino 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Google Earth 4 KMZ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Grana pellicola 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Grandangolo adattato 14.2, Copyright © 2014 Adobe Systems Incorporated - dal file “Adaptive Wide Angle.plugin”
                     Granulosità 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     HDRMergeUI 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “HDRMergeUI.plugin”
                     Includi filigrana VERSIONE NON DISPONIBILE - dal file “DigiSign.plugin”
                     Increspatura oceano 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Intermedio 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Intervallo 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Involucro di plastica 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     JPEG 2000 14.2.1 x001  ©2001-2014 Adobe Systems Incorporated - dal file “JPEG2000.plugin”
                     Leggi Filigrana VERSIONE NON DISPONIBILE - dal file “DigiRead.plugin”
                     Luce al neon 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Massimo 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Matita colorata 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Matlab Operation 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “ChannelPort.plugin”
                     Media 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “Average.plugin”
                     Media 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Mezzatinta 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Minimo 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Modulo Photoshop 3D 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “Photoshop3DEngine.plugin”
                     Muovi 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Nuvole 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “Clouds.plugin”
                     Nuvole in differenza 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “Clouds.plugin”
                     Ombra tratteggiata 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     OpenEXR 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Pastelli su superficie ruvida 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Patchwork 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Pattern mezzetinte 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     PCX 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - dal file “PCX.plugin”
                     Penna grafica 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Pennello a secco 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Photoshop Touch CC (14.2.0.0) ©1993-2014 Adobe Systems Incorporated - dal file “PSDX.plugin”
                     Pixar 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - dal file “Pixar.plugin”
                     Portable Bit Map 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - dal file “PBM.plugin”
                     Porzioni 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Porzioni mosaico 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Radiance 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - dal file “Radiance.plugin”
                     Riduzione effetto mosso 14.2, Copyright © 2014 Adobe Systems Incorporated - dal file “Shake Reduction.plugin”
                     Riflesso obiettivo 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Ritaglia e raddrizza foto 14.2.1 x001  ©2003-2014 Adobe Systems Incorporated - dal file “CropPhotosAuto.plugin”
                     Routine FastCore 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - dal file “FastCore.plugin”
                     Routine MMXCore 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - dal file “MMXCore.plugin”
                     Salva per Web 14.2, Copyright © 1999-2014 Adobe Systems Incorporated - dal file “Save for Web.plugin”
                     Sfocatura con obiettivo 14.2, Copyright © 2002-2014 Adobe Systems Incorporated - dal file “Lens Blur.plugin”
                     Sfocatura migliore 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Sfocatura radiale 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Solarizza 14.2.1 x001  ©1993-2014 Adobe Systems Incorporated - dal file “Solarize.plugin”
                     Sommatoria 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Spruzzo 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     STL 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Sumi-e 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Supporto multiprocessore 14.2.1 x001  ©1990-2014 Adobe Systems Incorporated - dal file “MultiProcessor Support.plugin”
                     SupportoScripting 14.2.1, Copyright © 2014 Adobe Systems Incorporated - dal file “ScriptingSupport.plugin”
                     Timbro 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Togli interlacciato 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Tracciati per Illustrator 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                     Tratti a spruzzo 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Tratti ad angolo 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Tratti scuri 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Varianza 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “statistics.plugin”
                     Vernice di fondo 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Vetro 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Vetro colorato 14.2, Copyright © 1991-2014 Adobe Systems Incorporated - dal file “Filter Gallery.plugin”
                     Wavefront|OBJ 14.2.1 x001  ©2006-2014 Adobe Systems Incorporated - dal file “U3D.plugin”
                     Wireless Bitmap 14.2.1 x001  ©1989-2014 Adobe Systems Incorporated - dal file “WBMP.plugin”
                     Zig zag 14.2, Copyright © 2003-2014 Adobe Systems Incorporated - dal file “Standard Multiplugin.plugin”
                  Plug-in opzionali e di terze parti:
                     Acquisisci Twain 13.0 20120315.r.428 2012/03/15:21:00:00  ©1992-2012 Adobe Systems Incorporated - dal file “TWAIN.plugin”
                     Analog Efex Pro 1.0.0.9, Copyright ©2000-2013, Google - dal file “Analog Efex Pro.plugin”
                     BackgroundFilter 2.2.0.9, Copyright ©2013 Google - dal file “BackgroundFilter.plugin”
                     Canon Easy-PhotoPrint Pro Canon Easy-PhotoPrint Pro Version 2.8.0 Copyright CANON INC. 2006-2013 All Rights Reserved. - dal file “EZPRPI01.plugin”
                     Canon Easy-PhotoPrint Pro Canon Easy-PhotoPrint Pro Version 2.8.0 Copyright CANON INC. 2006-2013 All Rights Reserved. - dal file “EZPRPI02.plugin”
                     Color Efex Pro 4 4.3.0.9, Copyright ©2000-2013, Google - dal file “Color Efex Pro 4.plugin”
                     Dfine 2 2.2.0.9, Copyright ©2013 Google - dal file “Dfine2.plugin”
                     FineStructuresFilter 2.2.0.9, Copyright ©2013 Google - dal file “FineStructuresFilter.plugin”
                     HDR Efex Pro 2 2.2.0.9, Copyright ©2000-2013, Google - dal file “HDR Efex Pro 2.plugin”
                     HotPixelsFilter 2.2.0.9, Copyright ©2013 Google - dal file “HotPixelsFilter.plugin”
                     Merge to HDR Efex Pro 2 2.2.0.9, Copyright ©2000-2013, Google - dal file “HDR Efex Pro 2 Automation.plugin”
                     Perfect Effects 8 8.1.0, Copyright © 2014 onOne Software.  All rights reserved. - dal file “Perfect Effects 8.plugin”
                     Perfect Effects 8 Filter 8.1.0, Copyright © 2014 onOne Software.  All rights reserved. - dal file “Perfect Effects 8.plugin”
                     Perfect Effects 8 Smart Filter 8.1.0, Copyright © 2014 onOne Software.  All rights reserved. - dal file “Perfect Effects 8.plugin”
                     Refocus VERSIONE NON DISPONIBILE - dal file “Refocus.plugin”
                     ShadowsFilter 2.2.0.9, Copyright ©2013 Google - dal file “ShadowsFilter.plugin”
                     Sharpener Pro 3: (1) RAW Presharpener 3.1.0.9, Copyright ©2013 Google - dal file “SHP3RPS.plugin”
                     Sharpener Pro 3: (2) Output Sharpener 3.1.0.9, Copyright ©2013 Google - dal file “SHP3OS.plugin”
                     Silver Efex Pro 2 2.2.0.9, Copyright ©2000-2013, Google - dal file “Silver Efex Pro 2.plugin”
                     SkinFilter 2.2.0.9, Copyright ©2013 Google - dal file “SkinFilter.plugin”
                     SkyFilter 2.2.0.9, Copyright ©2013 Google - dal file “SkyFilter.plugin”
                     StrongNoiseFilter 2.2.0.9, Copyright ©2013 Google - dal file “StrongNoiseFilter.plugin”
                     Viveza 2 2.1.0.9, Copyright ©2013 Google - dal file “Viveza2.plugin”
                  Impossibile caricare i seguenti plug-in: NESSUNO
                  Flash:
                     Mini Bridge
                     Kuler
                     Adobe Exchange
                  Periferiche TWAIN installate: NESSUNA
                  • 7. Re: Radial blur filter
                    Level 7
                    Have you tried disabling all those third party plugins?
                    And did you try deleting the OS font cache? (where I suspect the error would be)
                    Oh, and have you used any sort of "OS Cleaner" or "OS Optimizer" utility on your system?
