2 Replies Latest reply on Apr 25, 2014 8:14 AM by RtheFree
    Show the filename in a edit_text box in a stamp dialog
    RtheFree
      Im tryint to create a stamp that pops-up dialog.
      One of the dialog text box must be filled in by default with the filename of the document that has to be stamped.
      This is a part of the code:
      var dialog = {
      issuepurposeValue: "",
      reviewresultcodeValue: "",
      nextissuestatusValue: "",
      resubmissiondateValue: "",
      respdept1Value: "",
      sigrespdept1Value: "",
      relateddept1Value: "",
      sigrelateddept1Value: "",
      relateddept2Value: "",
      sigrelateddept2Value: "",
      dateValue: "",
      reqnumValue: "",
      docnumberValue: "",
      docrevValue: "",
      initialize: function(dialog) {
      dialog.load({
      "radA": true,
      "radF": true,
      "radL": true,
      "cbxA": true,
      "radP": true,
      "radR": false,
      "txtM": documentFileName,
      "txtK": util.printd("dd-mmm-yyyy", new Date()),
      this.dateValue = false;
      this.resubmissiondateValue = false
      dialog.enable({
      "txtD": this.resubmissiondateValue,
      "txtK": this.dateValue
      cbxA: function (dialog) {
      this.dateValue = !this.dateValue;
      dialog.enable({"txtK": this.dateValue});
      radR: function (dialog) {
      this.resubmissiondateValue =! this.resubmissiondateValue;
      dialog.enable({
      "txtD": true,
      radP: function (dialog) {
      dialog.enable({
      "txtD": false,
      radQ: function (dialog) {
      dialog.enable({
      "txtD": false,
      commit:function (dialog) { // called when OK pressed
      var results = dialog.store();
      if(results["radA"] == true) {this.issuepurposeValue = "FR"};
      if(results["radB"] == true) {this.issuepurposeValue = "FN"};
      if(results["radC"] == true) {this.issuepurposeValue = "FI"};
      if(results["radD"] == true) {this.issuepurposeValue = "AB"};
      if(results["radE"] == true) {this.issuepurposeValue = ""};
      if(results["radF"] == true) {this.reviewresultcodeValue = "A"};
      if(results["radG"] == true) {this.reviewresultcodeValue = "B"};
      if(results["radH"] == true) {this.reviewresultcodeValue = "N"};
      if(results["radI"] == true) {this.reviewresultcodeValue = "F"};
      if(results["radJ"] == true) {this.reviewresultcodeValue = ""};
      if(results["radK"] == true) {this.nextissuestatusValue = "FR"};
      if(results["radL"] == true) {this.nextissuestatusValue = "FN"};
      if(results["radM"] == true) {this.nextissuestatusValue = "FI"};
      if(results["radN"] == true) {this.nextissuestatusValue = "AB"};
      if(results["radO"] == true) {this.nextissuestatusValue = ""};
      if(results["radP"] == true) { this.resubmissiondateValue = "Within 2 weeks"};
      if(results["radQ"] == true) { this.resubmissiondateValue = "In MDR"};
      if(results["radR"] == true) { this.resubmissiondateValue = results["txtD"]};
      this.respdept1Value = results["txtE"];
      this.sigrespdept1Value = results["txtF"];
      this.relateddept1Value = results["txtG"];
      this.sigrelateddept1Value = results["txtH"];
      this.relateddept2Value = results["txtI"];
      this.sigrelateddept2Value = results["txtJ"];
      if(results["cbxA"] == false) {this.dateValue = results["txtK"]};
      if(results["cbxA"] == true) {this.dateValue = util.printd("dd-mmm-yyyy", new Date())};
      this.reqnumValue = results["txtL"];
      this.docnumberValue = results["txtM"];
      this.docrevValue = results["txtN"];
      description:
      The problem is in "txtM" if i put under initialize "txtM": documentFileName, it returns the stamp name and i need the filename.
      hope anyone can help.
      Robbert
        • 1. Re: Show the filename in a edit_text box in a stamp dialog
          "documentFileName" is the property of what JS object?
          It is a good coding practice to either explicitly use the object or provide a variable that provides the object.
          • 2. Re: Show the filename in a edit_text box in a stamp dialog
            RtheFree Level 1
            I'm not that good in writing java scripts codes. all my codes come from stealing and modifying with trial and error.
            for your understanding find below the complete stamp code. The stamp is being used as a company approval stamp. a part of this stamp provides the document number of the checked document. to make it easy for the user of the stamp i want to retrieve the document file name as this is most of the time equal to the document number it self.
            "txtM" is the id-tag for a type edit_text box for filling the document number.
            var dialog = {
            respdept1Value: "",
            dateValue: "",
            reqnumValue: "",
            docnumberValue: "",
            docrevValue: "",
            dialog.load({
            "radA": true,
            "radF": true,
            "radL": true,
            "cbxA": true,
            "radP": true,
            "radR": false,
            dialog.enable({
            dialog.enable({
            "txtD": true,
            dialog.enable({
            "txtD": false,
            dialog.enable({
            "txtD": false,
            description:
            name: "Issue Purpose Column",// Dialog box title
            elements:
            type: "cluster",
            name: "Purpose, Result and Next Issue",
            align_children: "align_left",
            elements:
            type: "view",
            align_children: "align_row",
            elements:
            name: "Issue Purpose",
            type: "static_text",
            char_width: 14,
            char_width: 1,
            type: "radio",
            item_id: "radA",
            group_id: "purp",
            name: "For Review (FR)",
            char_width: 14,
            type: "radio",
            item_id: "radB",
            group_id: "purp",
            name: "For Final (FN)",
            char_width: 14,
            type: "radio",
            item_id: "radC",
            group_id: "purp",
            name: "For Information (FI)" ,
            char_width: 14,
            type: "radio",
            item_id: "radD",
            group_id: "purp",
            name: "As Build (AB)" ,
            char_width: 14,
            type: "radio",
            item_id: "radE",
            group_id: "purp",
            name: "Not Applicable" ,
            type: "view",
            elements:
            name: "Review Result Code",
            char_width: 14,
            char_width: 1,
            type: "radio",
            item_id: "radF",
            group_id: "resu",
            name: "A Approved (A)",
            char_width: 14,
            type: "radio",
            item_id: "radG",
            group_id: "resu",
            name: "B Approved (B)",
            char_width: 14,
            type: "radio",
            item_id: "radH",
            group_id: "resu",
            name: "Not Accepted (N)" ,
            char_width: 14,
            type: "radio",
            item_id: "radI",
            group_id: "resu",
            name: "For Information (F)" ,
            char_width: 14,
            type: "radio",
            item_id: "radJ",
            group_id: "resu",
            type: "view",
            elements:
                                   name: "Next Issue Status ",
            char_width: 14,
            char_width: 1,
            type: "radio",
            item_id: "radK",
            group_id: "next",
            char_width: 14,
            type: "radio",
            item_id: "radL",
            group_id: "next",
            char_width: 14,
            type: "radio",
            item_id: "radM",
            group_id: "next",
            char_width: 14,
            type: "radio",
            item_id: "radN",
            group_id: "next",
            char_width: 14,
            type: "radio",
            item_id: "radO",
            group_id: "next",
            type: "view",
            elements:
            char_width: 14,
            char_width: 1,
            type: "radio",
            item_id: "radP",
            group_id: "resub",
            name: "Within 2 weeks" ,
            char_width: 14,
            type: "radio",
            item_id: "radQ",
            group_id: " resub ",
            name: "In MDR" ,
            char_width: 14,
            type: "radio",
            item_id: "radR",
            char_width: 1,
            item_id: "txtD",
            type: "edit_text",
            multiline: false,
            width: 308,
            height: 20
            type: "cluster",
            name: "Responsible Dept. and person",
            elements:
            type: "view",
            elements:
            name: "Responsible Department",
            char_width: 14,
            char_width: 1,
            item_id: "txtE",
            type: "edit_text",
            multiline: false,
            width: 100,
            height: 20
            name: "Responsible Person (Abbreviation)",
            char_width: 19,
            char_width: 1,
            item_id: "txtF",
            type: "edit_text",
            multiline: false,
            width: 371,
            height: 20
            type: "view",
            elements:
            name: "Related Department #1",
            char_width: 14,
            char_width: 1,
            item_id: "txtG",
            type: "edit_text",
            multiline: false,
            width: 100,
            height: 20
            name: "Related Person #1 (Abbreviation)",
            char_width: 19,
            char_width: 1,
            item_id: "txtH",
            type: "edit_text",
            multiline: false,
            width: 371,
            height: 20
            type: "view",
            elements:
            name: "Related Department #2",
            char_width: 14,
            char_width: 1,
            item_id: "txtI",
            type: "edit_text",
            multiline: false,
            width: 100,
            height: 20
            name: "Related Person #2 (Abbreviation)",
            char_width: 19,
            char_width: 1,
            item_id: "txtJ",
            type: "edit_text",
            multiline: false,
            width: 371,
            height: 20
            type: "cluster",
            name: "Document information",
            elements:
            type: "view",
            elements:
            char_width: 14,
            char_width: 1,
            type: "check_box",
            item_id: "cbxA",
            char_width: 1,
            item_id: "txtK",
            type: "edit_text",
            multiline: false,
            width: 189,
            height: 20
            type: "view",
            elements:
            char_width: 14,
            char_width: 1,
            item_id: "txtL",
            type: "edit_text",
            multiline: false,
            width: 300,
            height: 20
            type: "view",
            elements:
            char_width: 14,
            char_width: 1,
            item_id: "txtM",
            type: "edit_text",
            variable_Name: "edit",
            multiline: false,
            width: 300,
            height: 20
            char_width: 3,
            char_width: 1,
            item_id: "txtN",
            type: "edit_text",
            multiline: false,
            width: 50,
            height: 20
            type: "ok_cancel",
            ok_name: "Ok",
            cancel_name: "Cancel"
            //app.execDialog(dialog);
            if(event.source.forReal && (event.source.stampName == "#DXpvGqB1uiHTWNVyDOHTnC"))
              if ("ok" == app.execDialog(dialog))
            var cMsg = dialog.issuepurposeValue;
            event.value = "\n" + cMsg;
            event.source.source.info.reviewresultcode = cMsg;
            cMsg = "\n" + dialog.reviewresultcodeValue;
            this.getField("reviewresultcode").value = cMsg;
            event.source.source.info.nextissuestatus = cMsg;
            cMsg = "\n" + dialog.nextissuestatusValue;
            this.getField("nextissuestatus").value = cMsg;
            event.source.source.info.resubmissiondate = cMsg;
            cMsg = "\n" + dialog.resubmissiondateValue;
            this.getField("resubmissiondate").value = cMsg;
            event.source.source.info.respdept1 = cMsg;
            cMsg = "\n" + dialog.respdept1Value;
            this.getField("respdept1").value = cMsg;
            event.source.source.info.sigrespdept1 = cMsg;
            cMsg = "\n" + dialog.sigrespdept1Value;
            this.getField("sigrespdept1").value = cMsg;
            event.source.source.info.relateddept1 = cMsg;
            cMsg = "\n" + dialog.relateddept1Value;
            this.getField("relateddept1").value = cMsg;
            event.source.source.info.sigrelateddept1 = cMsg;
            cMsg = "\n" + dialog.sigrelateddept1Value;
            this.getField("sigrelateddept1").value = cMsg;
            event.source.source.info.relateddept2 = cMsg;
            cMsg = "\n" + dialog.relateddept2Value;
            this.getField("relateddept2").value = cMsg;
            event.source.source.info.sigrelateddept2 = cMsg;
            cMsg = "\n" + dialog.sigrelateddept2Value;
            this.getField("sigrelateddept2").value = cMsg;
            event.source.source.info.date = cMsg;
            cMsg = "\n" + dialog.dateValue;
            this.getField("date").value = cMsg;
            event.source.source.info.reqnum = cMsg;
            cMsg = "\n" + dialog.reqnumValue;
            this.getField("reqnum").value = cMsg;
            event.source.source.info.docnumber = cMsg;
            cMsg = "\n" + dialog.docnumberValue;
            this.getField("docnumber").value = cMsg;
            event.source.source.info.docrev = cMsg;
            cMsg = "\n" + dialog.docrevValue;
            this.getField("docrev").value = cMsg;
