0 Replies Latest reply on Apr 25, 2014 7:36 AM by cleo1308me
    HELP! InDesign CC got an error: The property is not applicable in the current state." number 30615
    cleo1308me
      HELP! Was working perfectly now it is giving me this error and doesn't seem to be going past the printing option. Code is below.
      main.scpt
      set posixIdPath to "/Applications/Adobe InDesign CC/Adobe InDesign CC.app"
      do shell script "/Users/cdapice/Desktop/cryptoquip/getquip.sh"
      delay 8
      tell application posixIdPath
      activate
      end tell
      delay 8
      set scripttoRun to ":Users:cdapice:Desktop:cryptoquip:Script.jsx" as alias
      tell application "Adobe InDesign CC"
      do script scripttoRun language javascript
      end tell
      delay 5
      Adobe InDesign CC got an error: The property is not applicable in the current state." number 30615
      Script.jsx
      var myDocument = app.open(File("/Users/cdapice/Desktop/cryptoquip/NewCryptoquip.indt"), true);
      //var myDocument = app.activeDocument;
      var myPage = myDocument.pages.item(0);
      var myTextFrame = myPage.textFrames.add();
      //Place a text file in the text frame.
      //Parameters for TextFrame.place():
      //File as File object,
      //[ShowingOptions as Boolean = False]
      //You'll have to fill in your own file path.
      myTextFrame.place(File("/Users/cdapice/Desktop/cryptoquip/quips.txt"));
      //var myTextFrame = app.selection[0];
      myTextFrame.parentStory.pointSize = 10;
      var brkStory = myTextFrame.parentStory.contents;
      var myPIs = myDocument.pageItems;
      var  destTextFrame = myPIs[6];
      destTextFrame.parentStory.contents = brkStory;
      firstChange();
      myTextFrame.remove();
      app.select(destTextFrame);
      splitStory();
      for (i = 0; i < myPIs.length; i++) {
                if (myPIs[i].appliedObjectStyle.name == "puzzleBox") {
                          var newBoxStyle = myPIs[i].appliedObjectStyle;
                          secondChange(myPIs[i]);
              myPIs[i].applyObjectStyle(newBoxStyle,true);
          if(myPIs[i].appliedObjectStyle.name == "otherBox"){
      Date.prototype.getMonthFormatted = function() {
          var month = this.getMonth() + 1;
          var formMonth = month < 10 ? '0' + month : month; // ('' + month) for string result
                return formMonth.toString();
      Date.prototype.getDayFormatted = function() {
          var day = this.getDate();
          var formDay = day < 10 ? '0' + day : day; // ('' + day) for string result
                return formDay.toString();
      var newdate = new Date();
      var laterdate = new Date();
      var dayofweek = newdate.getDay();
      var offsetdays = 0;
      switch(dayofweek) {
          case 2:
              offsetdays = 6;
              break;
          case 3:
              offsetdays = 5;
              break;
          case 4:
              offsetdays = 4;
              break;
          case 5:
              offsetdays = 3;
              break;
      app.epsExportPreferences.appliedFlattenerPreset.convertAllStrokesToOutlines = true;
      app.epsExportPreferences.appliedFlattenerPreset.convertAllTextToOutlines = true;
      app.epsExportPreferences.appliedFlattenerPreset.rasterVectorBalance = 100;
      //app.activeDocument.exportFile(ExportFormat.epsType, newFile, false);
      for (i = 1; i < 7; i++) {
          var curPage = i + "";
          var x = i + (offsetdays - 1);
          laterdate.setMonth(newdate.getMonth());
          laterdate.setDate(newdate.getDate());
          //alert(newdate);
          //alert(x);
          //alert(laterdate);
          laterdate.setDate(newdate.getDate() + x);
          //alert(laterdate);
          var nameDate = laterdate.getMonthFormatted() + laterdate.getDayFormatted() + ".eps"
          //alert(nameDate);
          app.epsExportPreferences.pageRange = curPage;
          var curFile = new File("/Users/cdapice/Desktop/cryptoquip/" + nameDate);
          app.activeDocument.exportFile(ExportFormat.epsType, curFile, false);
      var endDate = laterdate.getMonthFormatted() + laterdate.getDayFormatted();
      var firstDate = new Date();
      firstDate.setDate(newdate.getDate() + offsetdays);
      var startDate = firstDate.getMonthFormatted() + firstDate.getDayFormatted();
      var idFile = "cryptoquip_" + startDate + "_" + endDate + ".indd";
      app.activeDocument.save(new File("/Users/cdapice/Desktop/cryptoquip/" + idFile));
      with (app.activeDocument.printPreferences){
              printer = "Advertising - Creative - Color Xerox";
              copies = 1;
              pageRange = "1-6";
              paperSize = "US Letter";
              paperHeight = "11 in";
              paperWidth = "8.5 in";
              printPageOrientation = PrintPageOrientation.landscape;
              pagePosition = PagePositions.centered;
             scaleHeight = 100;
             scaleWidth = 100;
              scaleMode = ScaleModes.scaleWidthHeight;
              scaleProportional = true;
              pageInformationMarks = true;
              colorOutput = ColorOutputModes.COMPOSITE_CMYK;
      app.activeDocument.print(false);
      for(myCounter = app.documents.length; myCounter > 0; myCounter--){
      app.documents.item(myCounter-1).close(SaveOptions.no);
      function firstChange() {
                app.findTextPreferences = NothingEnum.NOTHING;
                app.changeTextPreferences = NothingEnum.NOTHING;
                app.findChangeTextOptions.caseSensitive = false;
          app.findTextPreferences.findWhat = "^t";
                app.changeTextPreferences.changeTo = "";
                myDocument.changeText();
           app.findTextPreferences.findWhat = "^p^p";
                app.changeTextPreferences.changeTo = "^p";
                app.findTextPreferences.findWhat = "^p";
                app.changeTextPreferences.changeTo = "^R";
      function secondChange(curFrame) {
          app.findTextPreferences.findWhat = "    ";
                app.changeTextPreferences.changeTo = "|";
                curFrame.changeText();
                app.findTextPreferences.findWhat = "|";
                app.changeTextPreferences.changeTo = " ";
      function splitStory(){
                //Make certain that user interaction (display of dialogs, etc.) is turned on.
                app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
                if(app.documents.length != 0){
                          if(app.selection.length != 0){
                                    //Get the first item in the selection.
                                    var mySelection = app.selection[0];
                                    //Process the selection. If text or a text frame is
                                    //selected, do something; otherwise, do nothing.
                                    switch(mySelection.constructor.name){
                                              case "Text":
                                              case "InsertionPoint":
                                              case "Character":
                                              case "Word":
                                              case "Line":
                                              case "TextStyleRange":
                                              case "Paragraph":
                                              case "TextColumn":
                                              case "TextFrame":
                                                        //If the text frame is the only text frame in the story, do nothing.
                                                        if(mySelection.parentStory.textContainers.length > 1){
        //Splitting the story is a two-step process: first, duplicate
        //the text frames, second, delete the original text frames.
        mySplitStory(mySelection.parentStory);
        myRemoveFrames(mySelection.parentStory);
                                                        else{
        alert("Please select a story containing more than one text frame and try again.");
                                                        break;
                                              default:
                                                        alert("Please select some text or a text frame and try again.");
                          else{
                else{
                          alert("Please open a document and try again.");
      function mySplitStory(myStory){
                var myTextFrame;
                //Duplicate each text frame in the story.
                for(var myCounter = myStory.textContainers.length-1; myCounter >= 0; myCounter --){
                          myTextFrame = myStory.textContainers[myCounter];
                          myTextFrame.duplicate();
      function myRemoveFrames(myStory){
                //Remove each text frame in the story. Iterate backwards to avoid invalid references.
                          myStory.textContainers[myCounter].remove();
