This content has been marked as final.
Show 3 replies
1. Re: PS6 How to reduce speckles from a scanned image
csuebele Apr 25, 2014 2:53 PM (in response to Melio123)FFT is used to reduce a pattern. Flecks may not register and need to be eliminated with the dust and scratches filter. Can you post an example?
2. Re: PS6 How to reduce speckles from a scanned image
Melio123 Apr 27, 2014 6:09 PM (in response to Melio123) -
3. Re: PS6 How to reduce speckles from a scanned image
csuebele Apr 27, 2014 7:29 PM (in response to Melio123)It's hard to tell with the resolution of the image you posted, in fact, because it doesn't look that bad in relation to paper texture. The FFT filter slightly blurs the image also. You might want to try making several scans of the image, rotating it each time then combine the scans using darken mode. There are some stuff on the web for a FFT filters for CS6 such as this:
http://www.retouchpro.com/forums/software/36732-fft-64bit-plugin.html
or
http://www.retouchpro.com/forums/software/33084-here-fft-64-bit-photoshop.html
