9 Replies Latest reply on Apr 28, 2014 8:08 AM by PleaseHelpMe
    Need Help With Variable Field Calculation
    PleaseHelpMe
      I am putting together a form and would like to have the calculations worked out for the people using the form to minimize errors. The premise of the equation is ...
      If suction pressure reads in PSIG, subtract from discharge to get total feet.
      If suction pressure reads in Vacuum, add to the discharge pressure to get total feet.
      My fields are set up as...
      Discharge Pressure PSIG
      Fixed           // fixed value of 2.31
      Discharge Calc
      Suction Pressure PSIG
      Fixed 1        // fixed value of 2.31
      V Suction Calc
      Suction Vacuum
      Fixed 2          // fixed value of 1.13
      S Suction Calc
      Total Feet
      In the form, I have the following field equations set up:
      Discharge Pressure PSIG x Fixed = Discharge Calc
      Suction Pressure PSIG x Fixed 1 = V Suction Calc
      Suction Vacuum x Fixed 2 = S Suction Calc
      So, I have assigned each of the fields I need to work with a variable name
      var v1 = Discharge Calc
      var v2 = V Suction Calc
      var v3 = S Suction Calc
      var v4 = Suction PSIG
      var v5 = Suction Vacuum
      What I think should work logically would be the follow:
      If v4 = 0, then v1+v3
      if v5 = 0, then v1-v2
      So, can you help me fix my script for the Total Feet field, please? I have no idea what I'm doing! This is what I have so far:
      var v1 = getField("Discharge Calc").value;
      var v2 = getField("V Suction Calc").value;
      var v3 = getField("Suction Calc").value;
      var v4 = getField("Suction PSIG").value;
      var v5 = getField("Suction Vacuum").value;
      if (v4=0)
           event.value = (v1+v3);
      if (v=5)
           event.value = (v1-v2);
      Many thanks for your help and have a nice day.
