1. Re: premiere pro cs6 - volumes/disk.........Splitter_Buffer.cpp-70 error
paulc89 May 1, 2014 12:13 PM (in response to paulc89)still happens after re-installing, does anyone have any ideas? i get the error message probably a few times every minute
2. Re: premiere pro cs6 - volumes/disk.........Splitter_Buffer.cpp-70 error
John T Smith May 1, 2014 12:19 PM (in response to paulc89)I am on Windows, but have a few saved Mac discussions that may help (or, may not... but free to read)
Mac and Root User http://forums.adobe.com/thread/879931
-and http://forums.adobe.com/thread/940869?tstart=0
Mac & nVidia Driver http://forums.adobe.com/thread/1075592
-and http://www.nvidia.com/object/mac-driver-archive.html
Mac Retina Bug http://forums.adobe.com/thread/1159632
Troubleshooting guide for Mac freeze
http://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-freezes-mac.html
External speakers stop playback http://forums.adobe.com/thread/1370072?tstart=0
Also, Go to http://forums.adobe.com/community/premiere and, in the area just under Ask a Question, type in
maverick
or
mavericks
or
10.9You may now read previous discussions on this subject... be sure to click the See More Results at the bottom of the initial, short list if the initial list does not answer your question
3. Re: premiere pro cs6 - volumes/disk.........Splitter_Buffer.cpp-70 error
Kusumas Dec 6, 2014 3:00 AM (in response to paulc89)I came across this with CS5, editing XDCAM footage on a PC. It seems likely that the .xml file that tracks the footage or the footage itself becomes somehow corrupted and causes this error. The solution I found (which might not be a good solution but it worked for me) was this:
1 Use Media Encoder to convert all the source footage into high-res H246 .mp4 files in a new location.
2 Rename the folder where all the original source video files are
3 Open the problem project and,when it says "Where is ... clip?" either go through each one, identifying the NEW versions that you have just converted or hit [Skip All] and do the right-click "Replace Footage" to use the new converted footage.
Continue editing with that footage instead.
Don't forget that you can try opening .bak backup versions of your project until you find one that works and move forward again from there.
