3 Replies Latest reply on Apr 26, 2014 10:15 AM by chinaDDD
    help with dialog list box(acrobat javascript)
    chinaDDD
      The following code is an example in the guide of acrobat. Now i want to list some names store in an array. So i did some changes.But it can't work.ther are errors with subl:{}. hope some help.
      var dialog3 = {
      name=new Array();
      name[1]=lucy;
      name[2]=lily;
      name[3]=han;
      // This dialog gets called when the dialog is created
      initialize: function(dialog) {
      this.loadDefaults(dialog);
      // This dialog gets called when the OK button is hit.
      commit: function(dialog) {
      // See the Dialog Object for a description of how dialog.load
      // and dialog.store work.
      var elements = dialog.store()["subl"];
      // do something with the data.
      // Callback for when the button "butn" is hit.
      butn: function(dialog) {
      for(var i in elements) {
      if ( elements[i] > 0 ) {
      app.alert("You chose \"" + i
      + "\", which has a value of " + elements[i] );
      loadDefaults: function (dialog) {
      dialog.load({
      subl:
           for(i=1;i<4;i++)
                name[i]:+i
      // The Dialog Description
      description:
      name: "Adobe Acrobat Products", // Title of dialog
      elements: // Child Element Array
      type: "view",
      align_children: "align_left",
      type: "cluster",
      type: "static_text",
      name: "Select Acrobat you use",
      font: "default"
      type: "list_box",
      item_id: "subl",
      width: 200,
      height: 60
      type: "button",
      item_id: "butn",
      type: "ok_cancel"
      app.execDialog(dialog3);
        • 1. Re: help with dialog list box(acrobat javascript)
          chinaDDD Level 1
          sorry ,the code is like this:
          name=new Array();
          name[1]='lucy';
          name[2]='lily';
          name[3]='han';
          var dialog3 = {
          dialog.load({
          subl:
                for(i=1;i<4;i++)
                  "name[i]":-i
          description:
          type: "view",
          type: "cluster",
          font: "default"
          type: "list_box",
          item_id: "subl",
          width: 200,
          height: 60
          type: "button",
          item_id: "butn",
          type: "ok_cancel"
          • 2. Re: help with dialog list box(acrobat javascript)
            This code returns an error. Also, in the load command you can't include an entire for-loop, as far as I know. You need to prepare the object you want to load before-hand and then just apply it in the load command.
            • 3. Re: help with dialog list box(acrobat javascript)
              chinaDDD Level 1
              thanks. I write a code to search the bookmarks that i want  and i need to display the results in a dialog box,so how to realize this function?
