1 Reply Latest reply on May 21, 2007 5:14 AM by peterent
    Flex Component Kit for Flash CS3
    David August
      HI,
      I am trying to use the "Flex Component Kit for Flash CS3" to import Flash applications into Flex so they can be converted into an Apollo application. The Extension seems to work except for the fact that if a flash cs3 component is included either inside the flash SWC or purely in actionscript it is unable understand how to use the component and all you see in flex is it playing the frames of the elements of the component. Also Flex only seems to understand actionscript in the root of the movieclip if it is nested then flex just ignores it. These problems may be related. Any help would be much appreciated Thanks.
      Dave
