3 Replies Latest reply on Apr 27, 2014 1:56 PM by A.T. Romano
    Audio out of sync - The source video caught with Game-Capture-Card (HD PVR 2)
    TatzyXY
      Helo Guys,
      I have a Problem with my Video-Game-Capture-Card (Hauppauge HD PVR 2 Gaming ED).
      When I finish my record the Video-Files works fine in VLC, WMP, etc.
      But If I import the video in PE, the audio get out of sync. The Audio gets out of sync, when I start playing the game in the video, if i stay whole time on desktop all is fine.
      I think its a problem with the frame rate which cause problems in PE.
      On Dekstop the FrameRate is 60 or what ever, in the Game it suddenly dynamic. Maybe this is the problem?
      I read the MediaInfos from the video file, there is no hint, thats the file have an dynamic frame rate.
      Maybe the problem is an other? Have you guys an hint, what i do wrong?
      In Sony Movie Studio it works also fine but i really prefer adobe PE.
      PS: Sorry for my english, which is the worst on planet!
      Here the file infos:
      General
      Complete name                            : C:\Users\Sven\Videos\xy.ts
      Format                                   : MPEG-TS
      File size                                : 437 MiB
      Duration                                 : 4mn 19s
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 14.1 Mbps
      Maximum Overall bit rate                 : 5 000 Kbps
      Video
      Menu ID                                  : 1 (0x1)
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format profile                           : High@L4.0
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 3 frames
      Codec ID                                 : 27
      Duration                                 : 4mn 19s
      Bit rate                                 : 13.2 Mbps
      Width                                    : 1 920 pixels
      Height                                   : 1 080 pixels
      Display aspect ratio                     : 16:9
      Frame rate                               : 29.970 fps
      Standard                                 : Component
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Bits/(Pixel*Frame)                       : 0.212
      Stream size                              : 407 MiB (93%)
      Color primaries                          : BT.709
      Transfer characteristics                 : BT.709
      Matrix coefficients                      : BT.709
      Audio
      Menu ID                                  : 1 (0x1)
      Format                                   : MPEG Audio
      Format version                           : Version 1
      Format profile                           : Layer 2
      Codec ID                                 : 3
      Duration                                 : 4mn 19s
      Bit rate mode                            : Constant
      Bit rate                                 : 256 Kbps
      Channel(s)                               : 2 channels
      Sampling rate                            : 48.0 KHz
      Compression mode                         : Lossy
      Delay relative to video                  : -20ms
      Stream size                              : 7.93 MiB (2%)
