3 Replies Latest reply on Apr 28, 2014 7:13 AM by Jump_Over
    Sum of All Opened Documents Pages
    creativejoan0425 Level 1
      I want to alert all opened documents pages, but is undefined, can anyone fix?
      var pageAlert = "";
      for (var i = 0; i < app.documents.length; i++) {
      var myDoc = app.documents[i];
                      var width = myDoc.documentPreferences.pageWidth;
                      var height = myDoc.documentPreferences.pageHeight;
                      var size = Math.round (width) + "mm x " + Math.round (height)+ "mm";
                      var eachDocPages = myDoc.pages.length;
      for (var j = 0; j < eachDocPages.length; j++) {
            var  totalPages = Math.max(eachDocPages[j]);
                      if(size == size){
                               pageAlert += "\n" + myDoc.name + " : " + size;
                      else {
                                 pageAlert = size;
      if (pageAlert.length) {
      alert("Paper Size: " + pageAlert + "\rTotal Pages: " + totalPages);
        • 1. Re: Sum of All Opened Documents Pages
          Jump_Over Level 5
          Cant be sure while comparing your description to a code, but if a goal is to alert set of page sizes and sum of count of pages ==>use this:
          var
                    pageAlert = "",
                    myDoc,
                    width, height, size,
                    eachDocPages, totalPages = 0,
                    i;
          for (i = 0; i < app.documents.length; i++) {
                    totalPages += eachDocPages;
          If the goal is to alert max page number (name) from all opened docs, use this:
          var
                    pageAlert = "",
                    myDoc,
                    currMax, maxPage = 0,
                    i;
               // here array of page names is sorted using custom function
                    currMax = myDoc.pages.everyItem().name.sort(sort_text2num)[0];
               // here max number is updated
                    maxPage = Math.max(maxPage, currMax);
                    alert("Paper Size: " + pageAlert + "\rTotal Pages: " + maxPage);
          function sort_text2num (a,b) {     // sort text as numbers in reverse order (max first)
                    return parseInt(a) <= parseInt(b);
          Jarek
          • 2. Re: Sum of All Opened Documents Pages
            But If my doc 1 have 2 pages the first page number call 2, the second 1
            doc2 the first page no 2, the second 3
            the total pages number should be 4, but the result is 3
            • 3. Re: Sum of All Opened Documents Pages
              Jump_Over Level 5
              1st code should return 4 (count of pages)
              2nd code should return 3 (max page number)
              Jarek
              PS. Script always should return what you want.
              The question is how concrete can you be with your expectations.
