10 Replies Latest reply on Sep 29, 2011 2:55 AM by Ram77
    TabNavigator tabIndexChange
    sahil1210
      Has anyone gotten the tabIndexChange event on TabNavigator to fire?
        • 1. Re: TabNavigator tabIndexChange
          AuroraCF
          Sahil,
          I am running into the same problem as you, no one respond to my post yet. Please let me know if you cn make it work.
          AuroraCF
          • 2. Re: TabNavigator tabIndexChange
            superkatakam Level 1
            i have the same problem too
            how can one fire the tabindexchange event?
            • 3. Re: TabNavigator tabIndexChange
              John Hall Level 4
              Could you share a simplified repo of code so we can see which event you're trying to act upon?
              • 4. Re: TabNavigator tabIndexChange
                <mx:Canvas>
                public function changeFunction(event:Event):void {
                     if(mainView.selectedIndex == 1 && x== 10)
                          Alert.show("Shouldnt Work");
                          mainView.selectedIndex = 0;
                <mx:TabNavigator change="changeFunction(event)" id="mainView" />
                </mx:Canvas>
                Inside TabNavigator, i have
                public function pieChangeFunction(event:Event):void {
                     drillDown();
                <mx:viewStack>
                <mx:PieChart id="pieChart" onClick="pieChangeFunction(event)"/>
                <mx:DataGrid.../>
                </mx:viewStack>
                when i put up the change function for the tabnavigator and try to call it in a main application, that part is fine but the pie chart click event gets messed up. because there is a change event being triggered inside the tabnavigator.
                I think i know that tabIndexChange event should work. But I cant even get the tabIndexChange to work.
                Could you please suggest me an idea?
                • 5. Re: TabNavigator tabIndexChange
                  John Hall Level 4
                  Have you tried anything like the following?
                          xmlns:mx="library://ns.adobe.com/flex/mx"
                          minWidth="955"
                          minHeight="600">
                       <fx:Script>
                            <![CDATA[
                                 import mx.events.IndexChangedEvent;
                                 import mx.controls.Alert;
                                 private function showMe( e : IndexChangedEvent ) : void {
                                      Alert.show( e.target.selectedIndex.toString());
                       </fx:Script>
                       <mx:TabNavigator id="myTabNav"
                             x="116"
                             y="57"
                             width="200"
                             height="200"
                             change="showMe(event)">
                            <s:NavigatorContent label="Tab 1"
                                 width="100%"
                                 height="100%">
                            </s:NavigatorContent>
                                 <s:NavigatorContent label="Tab 2"
                                 width="100%"
                                 height="100%">
                                 <s:NavigatorContent label="Tab 3"
                                 width="100%"
                                 height="100%">
                       </mx:TabNavigator>
                  </s:Application>
                  • 6. Re: TabNavigator tabIndexChange
                    i just tried it. when i clicked on my pie chart.
                    this error popped up
                    TypeError: Error #1034: Type Coercion failed: cannot convert mx.charts.events::ChartItemEvent@69b7221 to mx.events.IndexChangedEvent.
                    • 7. Re: TabNavigator tabIndexChange
                      Flex harUI Adobe Employee
                      If the Chart is bubbling a change event, you may need to call
                      stopImmediatePropagation on it before it bubbles to the tab navigator
                      • 8. Re: TabNavigator tabIndexChange
                        then i believe i shoudl do it for all my components inside the tab.
                        i'll give that a shot.
                        • 9. Re: TabNavigator tabIndexChange
                          there is also something thats happeneing in addition to that.
                          everytime i click on the tab, the new tab, kinda looks blurred. when i remove the event, it looks fine. when i say blurr, it looks like an overlap of the same page over each other. only that the overlap is not exactly one above the other and i end up seeing 2 pages of the same kind one on top of the other.
                          is that an issue with as3?
                          • 10. Re: TabNavigator tabIndexChange
                            Ram77
                            <mx:Script>
                            <![CDATA[
                            private function onTabIndexChange(e:IndexChangedEvent):void
        Alert.show(e.target.selectedIndex.toString());
                            </mx:Script>
                            <mx:TabNavigator width="100%" height="100%" paddingTop="0" change="onTabIndexChange(event)">
                                                          <mx:VBox width="100%" height="100%" label="Tab 1" verticalAlign="top">
                              </mx:VBox>
                              <mx:VBox width="100%" height="100%" label="Tab 2" verticalAlign="top">
                              </mx:VBox>
                              <mx:VBox width="100%" height="100%" label="Tab 3" verticalAlign="top">
                              </mx:VBox>
                            </mx:TabNavigator>
                            Hope this helps!!
                            Ram
