6 Replies Latest reply on Mar 11, 2015 12:53 PM by Zantcor
    Can anyone help with with this dialog?
    Eiranix Level 1
      I have put together a dialog but I'm not sure how to get it working properly...
      1) I want the checkbox to disable the last 3 fields and make their value be the same as the first field.
      2) have the variables from the fields and selected radio to come through into the alert
      #target illustrator
      //window
      var win = new Window('dialog', "My Dialog");
      this.windowRef = win;
      //panels
      win.fieldpanel = win.add("panel", undefined, "");
      win.radiopanel = win.add("panel", undefined, "");
      //panel orientation
      win.fieldpanel.orientation='row';
      win.radiopanel.orientation='row';
      //fieldpanel
      win.fieldpanel.panel1 = win.fieldpanel.add('panel', undefined, "Left");
      win.fieldpanel.panel2 = win.fieldpanel.add('panel', undefined, "Right");
      win.fieldpanel.panel3 = win.fieldpanel.add('panel', undefined, "Top");
      win.fieldpanel.panel4 = win.fieldpanel.add('panel', undefined, "Bottom");
      win.fieldpanel.panel1.left_input = win.fieldpanel.panel1.add('edittext', undefined, "0");
      win.fieldpanel.panel2.right_input = win.fieldpanel.panel2.add('edittext', undefined, "0");
      win.fieldpanel.panel3.top_input = win.fieldpanel.panel3.add('edittext', undefined, "0");
      win.fieldpanel.panel4.bottom_input = win.fieldpanel.panel4.add('edittext', undefined, "0");
      win.fieldpanel.panel1.left_input.characters = 5;
      win.fieldpanel.panel2.right_input.characters = 5;
      win.fieldpanel.panel3.top_input.characters = 5;
      win.fieldpanel.panel4.bottom_input.characters = 5;
      win.fieldpanel.check1 = win.fieldpanel.add('checkbox', undefined, "Equal");
      //radiopanel
      win.radiopanel.radio1 = win.radiopanel.add('radiobutton',undefined, "Option 1");
      win.radiopanel.radio2 = win.radiopanel.add('radiobutton',undefined, "Option 2");
      win.radiopanel.radio3 = win.radiopanel.add('radiobutton',undefined, "Option 3");
      //select first radio button
      win.radiopanel.radio1.value = true;
      //ok button
      win.okbutton = win.add('button',undefined, "Ok");
      //disable fields with checkbox and equal values
      win.fieldpanel.check1.onCLick = function() {
        if(win.fieldpanel.check1.value){
          var leftvalue = win.fieldpanel.left_input.text;
          win.fieldpanel.right_input.text = left;
          win.fieldpanel.top_input.text = left;
          win.fieldpanel.bottom_input.text = left;
          win.fieldpanel.right_input.enabled = false;
          win.fieldpanel.top_input.enabled = false;
          win.fieldpanel.bottom_input.enabled = false;
        } else {
          win.fieldpanel.right_input.enabled = true;
          win.fieldpanel.top_input.enabled = true;
          win.fieldpanel.bottom_input.enabled = true;
      //event listener for radio buttons
      win.radiopanel.radio1.onClick = win.radiopanel.radio2.onClick = win.radiopanel.radio3.onClick = function () {
        var selected = "";
        if(win.radiopanel.radio1.value) {
          selected = 1;
        else if(win.radiopanel.radio2.value) {
          selected = 2;
        else if(win.radiopanel.radio3.value) {
          selected = 3;
      //event listener for ok button
      win.okbutton.onClick = function(){
        var left = win.fieldpanel.left_input.text;
        var right = win.fieldpanel.right_input.text;
        var top = win.fieldpanel.top_input.text;
        var bottom = win.fieldpanel.bottom_input.text;
        if (selected = 1) {var option = "Option 1"};
        if (selected = 2) {var option = "Option 2"};
        if (selected = 3) {var option = "Option 3"};
        win.close();
        alert(left+", "+right+", "+top+", "+bottom+", "+option);
      win.show()
        • 1. Re: Can anyone help with with this dialog?
          CarlosCanto Adobe Community Professional & MVP
          you have a number of syntax errors, other than that it should work
          case sentive
          win.fieldpanel.check1.onCLick = function() { // misspelled
          in lots of lines like the below in pink you are missing panel1, panel2, panel3, panel4
              var leftvalue = win.fieldpanel.left_input.text; // missing panel1
          left is undefined, it should be leftvalue
              win.fieldpanel.right_input.text = left; // should be leftvalue
          • 2. Re: Can anyone help with with this dialog?
            Eiranix Level 1
            Edit- was being blind... Work great now thanks so much!
            Btw is it possible to have the three disabled fields mirror the first field as you type in it?
            • 3. Re: Can anyone help with with this dialog?
              Eiranix Level 1
              Ok I've just realised that the radio buttons always give "Option 3" in the alert, no matter which was selected... Any ideas?
                var selected = "";
                  selected = 1;
                  selected = 2;
                  selected = 3;
                win.close();
                alert(option);
              Edit: I moved the event listener for radio buttons function to inside the ok button function which solved the problem.
              • 4. Re: Can anyone help with with this dialog?
                you're welcome,
                yes, use the onChanging event on the first field.
                • 5. Re: Can anyone help with with this dialog?
                  Eiranix Level 1
                  Perfect, thanks again.
                  • 6. Re: Can anyone help with with this dialog?
                    Zantcor Level 1
                    I know this is old but I saw this as I was scrolling through the forums;
                    You have = instead of == in the if statement it should read like this;
                      if (selected == 1) {var option = "Option 1"};
                      if (selected == 2) {var option = "Option 2"};
                      if (selected == 3) {var option = "Option 3"};
                    as it was checking it was making the var selected = 3 as it was the last line you use one = to make it into something == to do a soft check so (a == A) is true but you use === to do a hard check so (a === A) would be false.
                    Hope that helps if you haven't figured it out already.
