8 Replies Latest reply on Apr 28, 2014 6:44 AM by boo radley 2013
    Suggestions for improvement - Brush Palette.
    donbarrum Level 2
      As many other professional artists using Photoshop I´m sure, I find the Brush Palette very hard to use. I´ve been annoyed by it for many years now, so I was hoping some of my suggestions coul reach Adobe.
      First of all, the actual representation of Brushes.
      I personally like to have my entire brush library in one file, not swap between brush files when sketching, painting and so on, because I like to use all of my brushes with instant accessability.
      But, it is SO hard to find the brushes. Especially because the generated icon most often doesnt represent the brushes look and behaviour at all. So often I do end up using just a few of them, because I don´t remember and have to spend time looking for for those I havent used for a while.
      This is how my brush palette looks:
      You can clearly see how this is confuzing. I´ve tried making some small brushes to show myself were the different paint, sketch, splatter, tree brushes etc are located. But it only helps so much.
      Wouldn´t it be a very nice feature if you could at least give them some visual prepresentation ? For example, you could colorize brushes the same way you can on layers. I would actually find it more useful on brushes than on layers.
      Just look at this:
      Also, I don´t understand a couple of the features that are present. Currently when you right click you can select a brush, and if you hold down alt you can delete and ctrl to rename. But to move the brushes around you have to go into the Preset Manager. VERY OFTEN my wacom tablet locks itself so that when I select the next brush it Deletes it before I have time to react. And this has been a problem in photoshop on all the wacom tablets I´ve tried. So I need to make sure to have the latest copy of my brushes always available to load up again.
      In my honest opinions, you shouldn´t be able to delete the brush from the right click brush panel. That´s somethign you definately should only be able to do inside the manager or at least it shouldnt lock itself on the pen to autodelete the next time you click a brush. But MOVING the brushes on the other hand, should definately BE POSSIBLE in the right click menu. Because you want to try out the brush you want to move. Since this is like a palette, you need to test and then group them so that they stay in order. It´s very annoying that you have to test the brush....then try to REMEMBER the location of that brush - go into the preset manager and try to find it, and then try to remember the location you wanted place it in. Do you see how difficult and tedious this is ?
      I hope someone at Adobe reads this and consider to make some improvements to this menu.
      PS! and another annoying this, is that if a brush is larger than a 1000px the leaps on the size slider suddenly jumps to 10x the amount. So its very hard to make a brush 1400 up to 1500 etc..
