1. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
pwillener Apr 28, 2014 11:12 PM (in response to cathillplayer)Can you open Adobe Reader by itself? If so, try disabling Protected Mode [Edit | Preferences | Security (Enhanced)].
If you cannot open Reader by itself, try to disable Protected Mode in the registry; download, unzip, then run the attached registry script
protected11.zip 338 bytes
2. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
cathillplayer Apr 29, 2014 1:40 AM (in response to pwillener)Hi Pat,
Thanks for the reply.
No, I can not open the Reader itself without this error message,
and even at a right-click on a PDF-file are administrator rights required.
Before I'll start the test with the zip file: What I do not understand is this. The Protected mode is still really important and so wanted by Adobe since Ver. 10X
When II turn off this permanently, will I loose this security feature??Greetings -
3. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
pwillener Apr 29, 2014 2:36 AM (in response to cathillplayer)Adobe insists that Protected Mode should not be turned off, as it is an important security feature.
On the other hand it causes so many problems that I routinely suggest to turn it off.
But it has also come to my attention that turning Protected Mode off, then back on again, many of these problems magically disappear. So maybe you want to try this?
4. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
cathillplayer Apr 29, 2014 2:56 AM (in response to pwillener)Hi Pat, Thank you,
I have merged the reg.file with my registry and the problem disapperard at once.
How to switch back this aktion, to see if the problem comes back again? Only delete the entry?
Greetings
5. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
pwillener Apr 29, 2014 6:21 PM (in response to cathillplayer)No, open Adobe Reader | Edit | Preferences | Security (Enhanced): check 'Enable Protected Mode at Startup'.
Reg scripts should only be used if normal Preference settings from within Adobe Reader are impossible.
6. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
cathillplayer May 1, 2014 2:51 AM (in response to pwillener)1 person found this helpfulHello Pat,
Thanks a lot,
When I did this, the Problem was back agien. So, I will use the reader further on without this securtiy feature and hope, that the comming up versions wil be able to run with enabled security mode again.
Greetings
7. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
KshaktiMay 13, 2014 7:17 AM (in response to cathillplayer)
Hi cathillplayer,
Please help me in understanding your problem better as on normal Win7 machines we don't get these issues.
Can you please let me know the following:
1) Exact operating system like Win7 (32bit or 64 bit) (Home, Enterprise or Ultimate) (Goto Computer , right click and you'll see the details in Windows Edition and system)
2) Any antivirus/ antimalware/ encryption software installed in your system? (It might be stopping Adobe Reader to open with protected mode enabled)
3) Are you login with any specific kind of user or normal administrator user ?
4) Is your system a part of any special file system?
5) Have you installed Adobe Reader at the default location (For 32-bit systems it is C:\Program Files\Adobe\Reader 11.0 and 64-bit it is C:\Program Files (x86)\Adobe\Reader 11.0 ) or any other location?
Shakti K
8. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
cathillplayer May 16, 2014 10:34 AM (in response to Kshakti)Hello Shakti,
1. It is Win7 Prof. 64 Bit
2. I am using Norton Internet security which includes anti-virus and firewall
3. I login as a User - not as an adminstrator. (Althouhg the problem was the same when I switched to th Admin-login or tried to execute Adobe-Reader as Admin)
4. no
5. It is installed under ´C:\Program Files (x86)\Adobe\Reader 11.0" (By the way: The Problems poped up after the last update to version 11 - not before.)
Greetings
cathillplayer
9. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
cathillplayer May 20, 2014 3:21 AM (in response to Kshakti)Hello Shtaki,
Yersterday I´ve got an update for the Acrobat Reader It is now 11.0.07.79.
Today I tried to re-enable Protected Mode at Startup --- and it works!!!
Seems to be a bug in the Version before.
Thanks for your help.
cathillplayer
10. Re: “Adobe Reader cannot open in Protected Mode due to a problem with your system configuration.
KshaktiMay 20, 2014 3:28 AM (in response to cathillplayer)
Hi cathillplayer,
Great to hear that.
Please keep protected mode at Startup always enabled as it is there to provide security to the users from vulnerabilities.
Shakti K
