4 Replies Latest reply on May 23, 2014 8:21 PM by Sarankup
    XML/MathML to PDF
    Sarankup
      I have XML with MathML inside, and I want to generate PDF. I have imported XML in FrameMaker template and formatted the XML with EDD support. However, all my MathML coding appear as text instead of Equation. I want to render all inline MathML tags as Equation. I aware that I can create Equation through "Special->MathML Equation" menu, but this approach seems like I need to re-create all equations one by one. Please advise.
        • 1. Re: XML/MathML to PDF
          Jite Adobe Employee
          First you need to wrap the mathML inside an element.
          For ex:-
          <MathML><math overflow="scroll">
             <mrow>
                <mover accent="true">
                 <mrow>
                     <mi>A</mi>
                     <mi>B</mi>
                  </mrow>
                  <mrow>
                     <mo>&rarr;</mo>
                  </mrow>
                </mover>
             </mrow>
          </math>
          </MathML>
          in your EDD you need to define a new element MathML which is MathMlEquation you also need to add InitailObjectFormat.-> All Context Rule ->MathMlEquation With Style -> Anchored frame Style.
          Create an Anchor frame style with position as inline.
          Also make sure that your dtd support your new MathMl Element.
          • 2. Re: XML/MathML to PDF
            Sarankup Level 1
            Hi Jite,
            Thanks. This is helpful. I have some difficult to set this. But, will it base-align the inline MathML equations as like as FM inbuilt equations? Because, the base-align in inline equations are the critical requirement in my automated project.
            • 3. Re: XML/MathML to PDF
              Jite Adobe Employee
              You need to manually set the baseline in the object style mentioned in the EDD currently. You can create three object style small , medium, large and adjust the Anchored frame style attribute  distance from baseline accordingly. (this will be negative in this case)
              • 4. Re: XML/MathML to PDF
                Sarankup Level 1
                Hi Jite,
                Thanks. We do professional typography service wherein base-align needs to be 100% accurate and no negotiations applicable. Unfortunately, your suggestion would not work fit for our requirement. The purpose of FrameMaker for us is to expect the professional output in PDF.
                Thank you so much for helping on this.
