1. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Jeff_Coatsworth Apr 28, 2014 11:26 AM (in response to Karl Lopata)Did you re-generate your WebHelp after applying the fix?
2. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Karl Lopata Apr 28, 2014 12:45 PM (in response to Jeff_Coatsworth)Thanks Jeff.
Yes, I did and restarted my machine and RoboHelp, generated a new project and still same results. Is there some IE setting that needs adjustment, maybe?
3. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Jeff_Coatsworth Apr 28, 2014 12:52 PM (in response to Karl Lopata)You can try making sure that JavaScript is enabled & that the location of your help is a “Trusted Site”
4. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Karl Lopata Apr 29, 2014 9:57 AM (in response to Jeff_Coatsworth)Thank you Jeff.
Finally, I was able to display WebHelp TOC, index, search in IE11 after I had copied the fix .js files also into the custom template folder that my company uses. However, when I start from the file I specified as the Start Page when generating the output, the WebHelp TOC, index, search wouldn't display again. It would only display correctly when I started from whnjs.htm.
5. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Jeff_Coatsworth Apr 29, 2014 10:58 AM (in response to Karl Lopata)“the custom template folder that my company uses” – huh? You sound like you’re doing something not quite “normal” in RH WebHelp terms here.
6. Re: TCS 4, RoboHelp 10: The WebHelp TOC, index, and glossary do not display any entries, even after down
Karl Lopata Apr 29, 2014 11:33 AM (in response to Jeff_Coatsworth)I agree, that's what makes troubleshooting even harder.
