8 Replies Latest reply on Apr 29, 2014 1:01 AM by Jump_Over
    Tables inside overset text frames
    schiuma24 Level 1
      Hi everybody!
      Im trying to write a script to set the width of all tables in a document equal to its parent text frame, I was succesful, but
      the tables that are overflowed do not get resized. I have only come up with a way to find if there is an overflowed text frame
      but not to find and overflowed text frame contents. PLS HELP!
      heres my code:
      //resizes tables
      var myTextFrames = app.activeDocument.textFrames.everyItem();
      var myTables = myTextFrames.tables.everyItem().getElements();
      for (var i = 0; i < myTables.length; i++){
               var myTextFrame =  myTables[i].parent;
                          var myWidth = myTextFrame.visibleBounds[3] - myTextFrame.visibleBounds[1];
                  myTables[i].width = myWidth;
      //finds a textframe with overset text
      var myOverset = app.activeDocument.textFrames.everyItem().getElements();
                      for(var x = 0; x < myOverset.length; x++){
                          if(myOverset[x].overflows == true){
                          alert("There is overset text")
        • 1. Re: Tables inside overset text frames
          Jump_Over Level 5
          Are your stories going through various wide textFrames?
          To work with stories instead of textFrames points you to each story.table, even overset ones.
          I mean:
          var myTables = app.activeDocument.stories.everyItem().tables.everyItem().getElements();
          If table[i].parent.constructor.name == "TextFrame"  ==> table is in visible part of text, so you can set the width of this frame
          If table[i].parent.constructor.name == "Story"     ==> table is in overset part of text, so you can set the width of story.textContainers[-1]
          Jarek
          • 2. Re: Tables inside overset text frames
            Kai Rübsamen Level 4
            I’m not sure, if I understand the goal correctly: You try to set the width of a table that is not visible, because the textframe overflows or because elements of the table overflows?
            If the first one is the case: It seems that the parent of a visual text is a textframe. But the parent of a non visible table is a story. If you try story.textFrames[0] the length == 0, but if you try story.textContainers[0] you get an result.
            Does that help?
            //resizes tables
            for ( var i = 0; i < myTables.length; i++ ){
                var container = myTables[i].parent;
            if ( container.constructor.name == "TextFrame" ) {
                var myTextFrame = container;
            else if ( container.constructor.name == "Story" ) {
                var myTextFrame = container.textContainers[0];
            Can someone tell me, why there are to differernt parent-elements here? Thanks.
            • 3. Re: Tables inside overset text frames
              Jump_Over Level 5
              Kai Rübsamen wrote:
              ...Can someone tell me, why there are to differernt parent-elements here?...
              Each object (child) suppose to have a parent. Basically for tables textFrame is a parent but sometimes they go wild, I mean they reduces their custody - in this case a story becomes responsible for...
              Table's life is brutal
              Jarek
              • 4. Re: Tables inside overset text frames
                schiuma24 Level 1
                thanks! you rock!
                • 5. Re: Tables inside overset text frames
                  @Kai – cool. Maybe just a little thing:
                  You suppose that the first text frame of a given story has the same width as the one with the overset (holding a table in the overflow).
                  So, if we have the following situation:
                  A table in the overflow will get too wide after running your script:
                  Instead of the first text frame in the story we could address the last one directly with:
                      var myTextFrame = container.textContainers[0].endTextFrame;
                  And the result will be:
                  The property endTextFrame is in the class of TextFrame.
                  We could also have written:
                      var myTextFrame = container.textContainers[container.textContainers.length-1];
                  Uwe
                  • 6. Re: Tables inside overset text frames
                    Hi Guys,
                    thanks for your response. Verry helpful to me .
                    @ Jarek: It seems, that story.textContainers[-1] does not work, because of textContainers is an array?!
                    @ Uwe: I thought to myself, that the first frame won’t be the right one in every case, but then I went to bed . Nevertheless I did not know endTextFrame and find also previousTextFrame,  nextTextFrame and startTextFrame, cool.
                    • 7. Re: Tables inside overset text frames
                      Exactly.
                      Uwe
                      • 8. Re: Tables inside overset text frames
                        Jump_Over Level 5
                        @ Kai, thats right.
                        I didn't check textContainers, sorry.
                        Jarek
