8 Replies Latest reply on Apr 29, 2014 8:25 PM by Trendyfroggy
    Problem with substraction with a negative number
    Trendyfroggy
      Hello,
      I wonder if someone could help me figure out how to script a calculation properly...
      I have field A   -  B   -  C  -  D -  E
      A = Expected Revenue
      B = Previous Withdrawals
      C = Fixed Annual Index = $26250
      D = 66.6% of (A-B)
      E = C - D
      I am trying to find the right script so that it would substract correctly when D is a negative number.
      Somehow E result indicates a negative number when it should in fact be a positive one and I'm not too sure why...
      In practice, it come to 26250 - (-D) which should therefore be 26250 + D but I always get a negative value for E???
      I am practicing on a Canadian Government Form for fanancial harship that is at http://www.osfi-bsif.gc.ca/Eng/Docs/form1.doc
      50% of the Year’s Maximum Pensionable
        Earnings as defined in the Pension Benefits Standards Act, 1985 is $26250.
      Any help would be greatly appreciated ;-)
        • 1. Re: Problem with substraction with a negative number
          Can you share the file you're working on?
          • 2. Re: Problem with substraction with a negative number
            JADarnell
            Hello Trendy:
               Have you tried something like this (this is from off the top of my head so you might have to make a few adjustments):
                if(C < D)
                  abs(D) - abs (C);
                else
                  abs(C) - abs(D);
            I know this is a bit of smoke and mirrors, but something like this should work if the idea is to force E to a positive value.  And btw, the abs function needs to come from the math object, I think.
            Good luck.
            John
            • 3. Re: Problem with substraction with a negative number
              It appears there is more to calculations for the "D: seires of fields:
              D Low Income Withdrawal component.
              $________
              Enter amount from D(1v) if greater than
              zero otherwise enter “0”
              D(i) A - B $________
              D(ii) 66.6% of D(i) $________
              D(iii) C - D(ii) $________
              D(iv) D(iii) - B(i) $_______
              • 4. Re: Problem with substraction with a negative number
                JADarnell Level 1
                Thanks for the additional information.  I'm not sure my advice applies at all any more.
                • 5. Re: Problem with substraction with a negative number
                  Trendyfroggy Level 1
                  Yes there is indeed...
                  This I managed to overcome by including :
                  var z = this.getField("D4").value;
                  if (z > 0) {
                  event.value = 0;
                  } else {
                  event.value = this.getField("D4").value;
                  This seems to be working well ;-)
                  • 6. Re: Problem with substraction with a negative number
                    Hi Gilad D,
                    Yeah how do I go about this sharing this file on here?
                    Sorry I'm rather a newbie on this community.
                    I have a PDF file ready...
                    • 7. Re: Problem with substraction with a negative number
                      No problem JADarnell,
                      Gosh why do they make these government forms so complicated??? lol
                      • 8. Re: Problem with substraction with a negative number
                        So I managed to advance. The calculation seems to be working well so far. I added in Bold the calculations entered in the Field Properties. The only thing that is blocking me now is the A value. A has to be equal or greater than B as B is automatically considered as revenue and is therefore included in A.
                        I tried a little trick by simply defining the value of A as the MINIMUM and I just selected B in the choices which seems to work meaning that when you change something in B1 or B2, it automatically changes the general value of B and therefore the A value picks up too that minimum value but the problem is that the rest of the calculations undeneath do not work anymore....
                        Any suggestions???
                        A
                        Expected income in this calendar year
                        determined in accordance with theIncome Tax Act.
                        $ ________
                        B
                        Total financial hardship withdrawals made
                        during the calendar year from all
                        federally-regulated locked-in registered
                        retirement savings plans, life income funds,
                        restricted life income funds and restricted
                        locked-in savings plans.
                        $ ________
                        B1 + B2
                        B(i): total low income component of B is
                        $ ________
                        B(ii): total medical and disability-related income component of B is
                        $ ________
                        C
                        Earnings as defined in the Pension Benefits Standards Act, 1985.
                        $ ________
                        Calculation Of Low Income Component Of Withdrawal
                        (To be completed only if seeking withdrawal under this component)
                        D
                        $________
                        if (z <= 0) {
                        event.value = 0;
                        } else {
                        Enter amount from D(1v) if greater than zero otherwise enter “0”
                        D(i)
                        A - B
                        $________
                        A - B
                        D(ii)
                        1. 66.6% of D(i)
                        $________
                        D1 * 0.666
                        D(iii)
                        C - D(ii)
                        $________
                        C - D2
                        D(iv)
                        D(iii) - B(i)
                        $________
                        D3 - B1
