6 Replies Latest reply: Apr 30, 2014 8:06 PM by Stan Jones RSS
    Bitrate too high
    chande a k Community Member
      I have a 60 Mts seq Exported from PremiereCS 6 for Blu-Ray at 20 Bitrate MAXIMUM 25. I tried to make an Image file in encore but I am getting message that Bitrate is too high at particular point encore  screen grab.jpg
      and  encore stops. Again I tried to export same project from premiere at lower Bitrate of 15 Maximum 20 but I got same error. So I tried to export from Premiere at CBR of 20 and Image file was created in Encore without any difficulty. Export was also quick. Now I want to know  Exporting Media from Premiere with CBR  is advisable or not
        • 1. Re: Bitrate too high
          Sandeep Singh Employee Hosts
          Hi chande a k,
          Thanks for posting on Adobe forums.
          Please tell us are you trying to create a menu in Encore and for that purpose you are importing image in Encore.
          1. what type of image you have ?
          2. what is the source of image ?
          Regards,
          Sandeep
          • 2. Re: Bitrate too high
            JSS1138 CommunityMVP
            [Moved to the Encore forum.]
            • 3. Re: Bitrate too high
              Stan Jones CommunityMVP
              Did you use the H264 Bluray preset for the PR export?
              Edit: do you have anything in the project other than the one file? This error may occur for other assets.
              A max 25 should be okay. but this usually reflects a real datarate issue.
              Edit 2: Sorry; did not note your question. CBR is fine if you have a short program.
              • 4. Re: Bitrate too high
                Thank you Sandeep for your reply.  In premiere cs 6 I had edited a musical programme, edited programme wasof 60mts. From premiere I exported H-264 Blu-Ray  with 20 Bitrate maximum 25 bitrate. usually I have not faced this sort of problem.   and from exported sequences, I make Image file in Encore, but this time I got repeatedly this  error. Since I had to deliver the Blu-ray urgently.  I tried to Export from Premiere timeline H-264 Blu-Ray with  CBR 20   this worked without any problem.   So I wanted to know is it OK to export from premiere timeline with CBR ?
                • 5. Re: Bitrate too high
                  Yes Jones it was H264 Bluray preset. and I had only one single HD 1920 - 1080 file FROM MY  Canon Mark III.   So. you want to say CBR is fine for short duration. But in my case 60 mts worked.   Should I continue using CBR  ?
                  • 6. Re: Bitrate too high
                    I'm not sure what that means.
                    CBR (constant bitrate) vs VBR (variable bitrate) makes a difference when the length of the program does not allow using that maximum bitrate throughout. If the program is relatively short, you can simply use CBR.
