1 Reply Latest reply on May 2, 2014 11:20 PM by Herbert2001
    Tidying up the attached plan
    gandalf458 Level 1
      Is there any way to tidy up the attached floor plan other than pixel by pixel so the lines are straight and without the "bumps" and fuzzy areas? I've played a bit with sharpen and even blur with limited effect. I'm using Fireworks 8.
        • 1. Re: Tidying up the attached plan
          Herbert2001 Level 4
          I would not bother with such a low resolution low quality image. It's best to redraw the entire thing quickly with the pen and line tools in Fireworks, which also gives you full control over line thickness and anti-aliasing.
          The drawing is quite simple, so it would take no more than 20~30 minutes to redraw it. Set the opacity for the image layer to a low one, and draw the new lines.
