4 Replies Latest reply on Apr 30, 2014 8:25 AM by JOHM:art
    Ae doesn't start anymore on OS X 10.9 (Ae Vers 12.2.1) HELP!
    JOHM:art
      I cant see any Error Massage or number and i can't make a crash report. Whats happend? Just the following massage i see. It's german and means that After Effects can not continue cause it's a unexpected error at the start up of this application
      german massage
      "After Effects kann nicht fortgesetzt werden: Unerwarteter Fehler beim Starten der Anwendung"
      I reinstalled but nothing is change and i restarted also but nothing
      What should i do?
        • 1. Re: Ae doesn't start anymore on OS X 10.9 (Ae Vers 12.2.1) HELP!
          Todd_Kopriva Level 8
          Begin by deleting the entire preferences folder:
          DRIVE/Users/USERNAME/Library/Preferences/Adobe/After Effects/
          Then start the application.
          If that doesn't work, then we need a lot more information to help you:
          http://forums.adobe.com/thread/961743
          • 2. Re: Ae doesn't start anymore on OS X 10.9 (Ae Vers 12.2.1) HELP!
            JOHM:art Level 1
            thanks a lot for your service and the fast answer but i try and it was the same like before. Here my info's... Hope that will be helpful. It's an hackintosh computer but I'd always worked with Ae on this comp. I never had any problems like this and it still came's only after the12.2 update i think. not sure.... I'm cc member since a whyle and i have the student abo.
            Model Name:  Mac Pro
            Model Type:  Early 2008
            Model Identifier:  MacPro3,1
            Board Identifier:  Mac-F42C88C8
            Processor Name:  Intel Core i7 CPU 920
            Processor Model:  Harpertown
            Processor Speed:  3.2 GHz
            Number of Processors:  1
            Total Number of Cores:  4
            Memory Size:  24 GB 1280 MHz DDR3
            Graphics Model:  AMD Radeon HD 6xxx 1024 MB
            Assembled in:  United States
            Manufactured during:  June 2008
            L1 Cache:  64 KB
            L2 Cache:  256 KB (per Core)
            L3 Cache:  8 MB
            Processor Bitrate:  64 bit
            EFI Bitrate:  64 bit
            Kernel Bitrate:  64 bit
            Processor Interconnect Speed:  5.8 GT/s
            Boot ROM Version:  MultiBeast.tonymacx86.com
            System SMC Version:  1.30f3
            Power Source:  AC Power.
            Hardware Universal Unique Identifier:  7F47AAF4-E8DB-5916-B95C-70DD3AE58CAC
            Minimum Supported Operating System:  OS X 10.5.1 Build 9B2117 (Leopard)
            Current Boot Operating System:  OS X 10.9.2 Build 13C1021 (Mavericks)
            Maximum Supported Operating System:  Latest version of OS X 10.9 (Mavericks)
            So i found some other problems and mybe thats the same source... Cinema 4D Lite doesn't start also. On the MAXON website i found that exist some troubles with ATI graphic chips under Mac OS X
            • 3. Re: Ae doesn't start anymore on OS X 10.9 (Ae Vers 12.2.1) HELP!
              A hackintosh is not a supported system for After Effects.
              • 4. Re: Ae doesn't start anymore on OS X 10.9 (Ae Vers 12.2.1) HELP!
                JOHM:art Level 1
                I have this computer since 3 years and i worked all the time with after effects and the other adobe programms. I've paid for the software and i use a regular intel based computer....
