6 Replies Latest reply on May 1, 2014 7:57 AM by 4everJang
    Output function (results to a file) in Extendscript
    klk_nc Level 1
      When I check a script I use the alert to see if the code is working, such as "Current tag is body".
      Is there a function that outputs alert results to a file? For example, a way to send to a file all
      of the paragraph tags that are used in a document. (The actual code could be a loop). I could
      use this as a start to produce what I really want, an array of all the valid tags, and then print to a file
      a list of all the "rogue" tags that are not in the valid list
        • 1. Re: Output function (results to a file) in Extendscript
          4everJang Level 3
          Check the JavaScript Tools Guide for details about the File object. Basically, it works more or less like this:
          var oFile = new File ( /* full path name as text string */ );
          oFile.open( "w" );     /* use "a" to append, "w" to remove existing text.
          oFile.writeln ( "Whatever you want to write in there" );
          oFile.close (  );
          Ciao
          Jang
          • 2. Re: Output function (results to a file) in Extendscript
            klk_nc Level 1
            Here's the code I have, but the Extendscript debugger says oFile.open is not a function, is this only for javascript?
            Keith
            function processDoc (doc) {
                    //Process the paragraphs and tables in the main document flow
                    var textList, count = 0, i = 0, tbl = 0, pgf = 0;
                    var oFile = "c:\myname\tags-list.txt";
                    // Turn off the document display to speed the script and
                    // prevent screen flicker.
                    if (app.Displaying == 1) {
                    app.Displaying = 0;
                    //Process each top-level paragraph in document
                    oFile.open("a");
                    pgf = doc.MainFlowInDoc.FirstTextFrameInFlow.FirstPgf;
                    while (pgf.ObjectValid()) {
                //!!    applyNewPgfFmt(pgf,doc);
                oFile.Writeln(pgf.Name);
                        pgf = pgf.NextPgfInFlow;
                oFile.close();
            • 3. Re: Output function (results to a file) in Extendscript
              klk_nc Level 1
              OK, was in a hurry, see that the new is a resreved word, this should be closer, there are no errors but no text output, I'll keep trying...
                      var tagsFile = new File ("C:\extend\tag_list.txt")
                      app.Displaying = 0;
                      tagsFile.open("a");
                          tagsFile.writeln (pgf.NextPgfInFlow);
                          // pgf = pgf.NextPgfInFlow;
                  tagsFile.close();
              • 4. Re: Output function (results to a file) in Extendscript
                4everJang Level 3
                Keith,
                There are a couple of problems with your script.
                1. You need to 'escape' the backslash in strings. So the code for creating your file should look like this:
                var tagsFile = new File ("C:\\extend\tag_list.txt")
                2. You cannot write the pgf to a text file as the pgf is an object that contains a whole lot of properties. I am not sure which property you want to write to the text file, but if you want to write the paragraph format tag, you should use:
                tagsFile.writeln (pgf.NextPgfInFlow.Name);
                Good luck
                Jang
                • 5. Re: Output function (results to a file) in Extendscript
                  klk_nc Level 1
                  Thanks, I got it to work, with using foraward slashes and an extra step, is there an advantage to your code? Sometimes mine will lock up Frame:
                          var tagsFile = new File ("/<path>/For_Keith/tag_list.txt")
                          alert (tagsFile);
                          app.Displaying = 0;
                          tagsFile.open("w");
                              tagsFile.writeln (pgf.Name);
                       tagsFile.close();
                  • 6. Re: Output function (results to a file) in Extendscript
                    4everJang Level 3
                    Hi Keith,
                    I can't tell why Frame sometimes locks up, as I don't know what your applyNewPgfFmt function looks like. I would keep displaying on until the code is perfected and well-tested, then use the debug mode to step through until it hits the spot where Frame locks up. You can also write debug messages to either a text file or the console, simply by using the function Console( "message" );
                    Good luck
                    Jang
