12 Replies Latest reply on Apr 30, 2014 1:22 PM by freedog69
    What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
    freedog69
      I have a Canon HF10 camera and I am trying to import the video but can't seem to find a setting that does not require significant rendering before the file is even editted. I am currently using  NTSC > AVCHD-HD1080i30    Once I import a file I get the redline across the top of the timeline.  I have tried just about every preset the app offers.
      My imported file says video is 1440 x 1080 BR 7300kbps FR 29 fs  audio is 256kbps sample rate 48k
      Chris
        • 1. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
          A.T. Romano Level 7
          Chris
          What is telling you that your video is 1440 x 1080 @ 29.97 interlaced frames per second -
          Edit Menu/Project Settings/General and the readouts for Editing Mode/Timebase/Frame Size/Pixel Aspect Ratio
          or
          Properties from right clicking the file in Project Media and selecting Properties
          If your video is 1440 x 1080 HD anamorphic 16:9, then your Premiere Elements 8.0/8.0.1 project preset should be
          NTSC
          AVCHD
          HD 1080i30
          and you should not be getting a red line over that content when you first drag it to the Timeline. However for every edit of that video, there will be the appearance of the red line with the render me implication to get the best possible preview.
          Please let us know if you see anything in the above that is not the case.
          Thank you.
          ATR
          • 2. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
            freedog69 Level 1
            AT thank you for your quick reply.  That is the setting I am using in PE 8.0.  Here is the properties of the mts video file  that I have copied from my camera to my pc.  Using the preset you instructed I get a redline as soon as I bring it into the timeline.
            General
            Complete name                        : C:\Users\chris\Desktop\4-28-14 Tap\AVCHD\BDMV\STREAM\00001.MTS
            Format                               : BDAV
            Format/Info                          : Blu-ray Video
            File size                            : 1.90 GiB
            Duration                             : 37mn 19s
            Overall bit rate mode                : Variable
            Overall bit rate                     : 7 301 Kbps
            Maximum Overall bit rate             : 13.7 Mbps
            Video
            Menu ID                              : 1 (0x1)
            Format                               : AVC
            Format/Info                          : Advanced Video Codec
            Format profile                       : High@L4.0
            Format settings, CABAC               : Yes
            Format settings, ReFrames            : 2 frames
            Format settings, GOP                 : M=3, N=15
            Codec ID                             : 27
            Duration                             : 37mn 19s
            Bit rate mode                        : Variable
            Bit rate                             : 6 747 Kbps
            Maximum bit rate                     : 12.0 Mbps
            Width                                : 1 440 pixels
            Height                               : 1 080 pixels
            Display aspect ratio                 : 16:9
            Frame rate                           : 29.970 fps
            Color space                          : YUV
            Chroma subsampling                   : 4:2:0
            Bit depth                            : 8 bits
            Scan type                            : Interlaced
            Scan order                           : Top Field First
            Bits/(Pixel*Frame)                   : 0.145
            Stream size                          : 1.76 GiB (92%)
            Audio
            Menu ID                              : 1 (0x1)
            Format                               : AC-3
            Format/Info                          : Audio Coding 3
            Mode extension                       : CM (complete main)
            Format settings, Endianness          : Big
            Codec ID                             : 129
            Duration                             : 37mn 19s
            Bit rate mode                        : Constant
            Bit rate                             : 256 Kbps
            Channel(s)                           : 2 channels
            Channel positions                    : Front: L R
            Sampling rate                        : 48.0 KHz
            Bit depth                            : 16 bits
            Compression mode                     : Lossy
            Delay relative to video              : -67ms
            Stream size                          : 68.3 MiB (4%)
            • 3. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
              A.T. Romano Level 7
              freedog69
              Thanks for the supplemental and confirming data. Puzzlement why you are getting that red line over the Timeline content when it is first dragged to the Timeline. Any chance you could post a small sample of this video as a Dropbox link in a reply here.
              But in the meanwhile, please important this file into a new project with the project preset set at
              NTSC
              Hard Disk, Flash Memory Camcorder
              HD1080i30
              and determine if you still get the red line over the content when it is first dragged to the Timeline.
              When you do get this red line on the first video drag to the Timeline, do you get an acceptable playback of the content in the Edit area monitor?
              More later.
              Thanks.
              ATR
              • 4. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                freedog69 Level 1
                I have created a test file that you can download here- https://dl.dropboxusercontent.com/u/7354008/test.mts
                When I try to import this same test file I get the redline over the timeline.  The playback is jerky for the most part if I don't render.
                General
                Complete name                            : C:\Users\chris\Desktop\test.mts
                Format                                   : AVI
                Format/Info                              : Audio Video Interleave
                File size                                : 20.9 MiB
                Duration                                 : 29s 952ms
                Overall bit rate                         : 5 863 Kbps
                Video
                Format                                   : AVC
                Codec ID                                 : H264
                Duration                                 : 29s 947ms
                Bit rate                                 : 5 511 Kbps
                Frame rate                               : 59.940 fps
                Original frame rate                      : 29.970 fps
                Color space                              : YUV
                Bit depth                                : 8 bits
                Bits/(Pixel*Frame)                       : 0.059
                Stream size                              : 19.7 MiB (94%)
                Audio
                Format                                   : AC-3
                Codec ID                                 : 2000
                Bit rate                                 : 256 Kbps
                Bit depth                                : 16 bits
                Stream size                              : 936 KiB (4%)
                Alignment                                : Aligned on interleaves
                Interleave, duration                     : 32 ms (1.92 video frames)
                • 5. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                  A.T. Romano Level 7
                  freedog69
                  Thanks for the sample, test.mts.
                  It will not open in Premiere Elements 8.0/8.0.1 or Premiere Elements 12 on Windows 7 64 bit.
                  I have renamed the file extension from mts to .m2ts, .mpg, and .mp4. That did not help.
                  Just looking at the MediaInfo properties readout is telling me why you are getting a red line over the Timeline content when you are able to import the file into Premiere Elements 8.0/8.0.1 with the project preset
                  NTSC
                  AVCHD
                  HD1080i30
                  Your file has a frame rate of 59.94 interlaced frames per second. There is no project preset for 1440 x 1080 HD anamorphic 16:9 @ 59.94 interlaced frames per second. So, even if you get the file to import, it will have a red line over its content.
                  But, the MediaInfo properties readout points to something that needs clarification. And, the clarification may lead to answers to the overall issues here. The frame rate is shown as 59.94 frames per second. And, under that, it says original frame rate 29.97 frames per second. When and how did the frame rate of that video get changed?
                  Please review and consider. If you have an alternative test.mts for me to check out, please do not hesitate to send it.
                  Thanks.
                  ATR
                  • 6. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                    freedog69 Level 1
                    Hello AT-
                    I took the original file that was MTS and used avidemux to trim it down to a suitable size to UL.  In that app all I did was trimed the video and saved it.  Is there another way I can trim down the video length without changing any properties?  I remade a new test clip here is the properties of test3.mts
                    https://dl.dropboxusercontent.com/u/7354008/test3.mts
                    General
                    Complete name                            : C:\Users\chris\Desktop\test3.mts
                    Format                                   : AVI
                    File size                                : 36.8 MiB
                    Duration                                 : 29s 864ms
                    Overall bit rate                         : 10.3 Mbps
                    Video
                    Format                                   : MPEG-4 Visual
                    Format profile                           : Advanced Simple@L4
                    Format settings, BVOP                    : 2
                    Format settings, QPel                    : No
                    Format settings, GMC                     : No warppoints
                    Format settings, Matrix                  : Default (H.263)
                    Codec ID                                 : DIVX
                    Codec ID/Info                            : Project Mayo
                    Codec ID/Hint                            : DivX 4
                    Bit rate                                 : 9 992 Kbps
                    Display aspect ratio                     : 4:3
                    Color space                              : YUV
                    Bit depth                                : 8 bits
                    Scan type                                : Progressive
                    Bits/(Pixel*Frame)                       : 0.214
                    Stream size                              : 35.6 MiB (97%)
                    Writing library                          : XviD 64
                    Audio
                    Format                                   : AC-3
                    Codec ID                                 : 2000
                    Duration                                 : 29s 792ms
                    Bit rate                                 : 256 Kbps
                    Bit depth                                : 16 bits
                    Stream size                              : 931 KiB (2%)
                    Interleave, duration                     : 32 ms (0.96 video frame)
                    • 7. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                      A.T. Romano Level 7
                      freedog69
                      Thanks for the follow ups.
                      I am in the process of downloading the test3.mts. I will put that through the tests. But, I have misgivings since the video codec in this one is DviX which is not a preferred video codec for Premiere Elements. That XviD is worse case.
                      Back soon with latest results.
                      Thanks.
                      ATR
                      • 8. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                        freedog69 Level 1
                        What is the best video codec for PE?  Can you give me a step by step from the camera to the pc to PE?  Am I doing something wrong?  Thanks
                        • 9. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                          A.T. Romano Level 7
                          freedpg69
                          This latest sample (DviX.mts) would not import into Premiere Elements 12 on my computer (Windows 7 Professional SP1 64 bit).
                          Do you have any AVCHD.mts 1440 x 1080 HD anamorphic 16:9 @ 29.97 interlaced frames per second that you can send?
                          More later.
                          ATR
                          • 10. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                            freedog69 Level 1
                            ok I went and created a new file on my HF10 and copied the file from camera to my pc here it is-  https://dl.dropboxusercontent.com/u/7354008/00000.MTS
                            here is its properties
                            General
                            Complete name                            : C:\Users\chris\Desktop\BDMV\STREAM\00000.MTS
                            Format                                   : BDAV
                            File size                                : 17.3 MiB
                            Duration                                 : 21s 150ms
                            Overall bit rate                         : 6 839 Kbps
                            Video
                            Menu ID                                  : 1 (0x1)
                            Format                                   : AVC
                            Codec ID                                 : 27
                            Duration                                 : 20s 954ms
                            Bit rate                                 : 6 303 Kbps
                            Color space                              : YUV
                            Bit depth                                : 8 bits
                            Bits/(Pixel*Frame)                       : 0.135
                            Stream size                              : 15.7 MiB (91%)
                            Audio
                            Menu ID                                  : 1 (0x1)
                            Format                                   : AC-3
                            Codec ID                                 : 129
                            Duration                                 : 21s 24ms
                            Bit rate                                 : 256 Kbps
                            Bit depth                                : 16 bits
                            Stream size                              : 657 KiB (4%)
                            • 11. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                              A.T. Romano Level 7
                              freedog69
                              If you have the Canon HF10 and you have it set to record to 1440 x 1080 HD anamorphic 16:9 @ 29.97 interlaced frames per second, what is it recording to
                              a. SD or SDHC memory card or built in camera memory?
                              How are you getting that video into the computer and then into Premiere Elements 8.0/8.0.1?
                              a. Are you letting the camera software work on the file first and then you transfer the video to the computer. And, then get the video into Premiere Elements 8.0/8.0.1 with Get Media/Files and Folders.
                              b. Some other variation?
                              If you have a camera software helping, I am wondering if the camera software is set to alter the original video properties of AVCHD.mts to something else?
                              Assuming that you are importing the video into the computer/Premiere Elements without any help from a Canon bundled in software, are you
                              a. going camera with memory inside, USB connection to computer, and then import into Premiere Elements using Get Media/Files and Folders after you set the project preset to NTSC AVCHD HD1080i30
                              or
                              Get Media/"AVCHD or other hard disk/memory camcorder"/"Adobe Premiere Elements - Media Downloader" after you set the project preset to NTSC AVCHD HD1080i30.
                              If you go just from Camera to computer, what file extension does the file have, .mts or something else?
                              If you have a 1440 x 1080 HD anamorphic 16:9 @ 29.97 interlaced frames per second importing into Premiere Elements 8.0/8.0.1 and you set the project preset for NTSC AVCHD HD1080i30, then there should not be seeing a red line over that Timeline content. If you are, there is something subtle in that file that is causing the red line indicator.
                              If you are able to import that video into Premiere Elements, right click the file in Project Media, and select Interpret Footage, what is shown in the Frame Rate section of Interpret Footage...29.97 frames per second or something else?
                              When all is said and done, if we cannot find an answer to the why red line, then I would ask how does the video export with or without the red line over the Timeline content?
                              More later.
                              Thanks.
                              ATR
                              • 12. Re: What is the best project setting in Adobe PE 8 for Canon HF10 Camera?
                                freedog69 Level 1
                                User left click in "caption"        Mouse Left Click        794,560        0,0,1280,800                                                      screenshot_0001.jpeg                    User left clicked        Mouse Left Click        804,441        0,0,1280,800        screenshot_0002.jpeg                    User left click on "This project already exists.  Confirm overwrite?  (This action is not undoable!) (push button)"        Mouse Left Click        687,410        0,0,1280,800        screenshot_0003.jpeg                    User left click in "Adobe Premiere Elements"        Mouse Left Click        687,410        0,0,1280,800        screenshot_0004.jpeg                    User Comment: "Created new project with settings specified"        0,0,1280,800        0,0,0,0        screenshot_0005.jpeg                    User left click on "Windows Explorer (push button)"        Mouse Left Click        142,787        0,0,1280,800        screenshot_0006.jpeg                    User left click on "Desktop (outline item)" in "Libraries"        Mouse Left Click        507,171        0,0,1280,800        screenshot_0007.jpeg                    User left click on "Page down (push button)" in "Desktop"        Mouse Left Click        1212,545        0,0,1280,800        screenshot_0008.jpeg                    User left double click on "BDMV (list item)" in "Desktop"        Mouse Left Double Click        884,314        0,0,1280,800        screenshot_0009.jpeg                    User left double click on "STREAM (list item)" in "BDMV"        Mouse Left Double Click        618,230        0,0,1280,800        screenshot_0010.jpeg                    User Comment: "Here is the file I copied via usb direct from my camera not using any software.  Just straight copy from the AVCHD folder"        0,0,1280,800        0,0,0,0        screenshot_0011.jpeg                    User mouse drag start in "STREAM"        Mouse Drag Start        702,44        0,0,1280,800                                            screenshot_0012.jpeg                    User mouse drag end in "STREAM"        Mouse Drag End        611,131        0,0,1280,800                                            screenshot_0013.jpeg                    User left click on "Close (push button)" in "STREAM"        Mouse Left Click        1113,136        0,0,1280,800                                                      screenshot_0014.jpeg                    User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"        Mouse Left Click        739,100        0,0,1280,800        screenshot_0015.jpeg                    User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"        Mouse Left Click        761,378        0,0,1280,800        screenshot_0016.jpeg                    User left click on "00000.MTS (list item)" in "Add Media"        Mouse Left Click        521,291        0,0,1280,800        screenshot_0017.jpeg                    User left click on "Open (push button)" in "Add Media"        Mouse Left Click        859,519        0,0,1280,800                                                      screenshot_0018.jpeg                    User mouse drag start in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"        Mouse Drag Start        612,256        0,0,1280,800        screenshot_0019.jpeg                    User mouse drag end in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"        Mouse Drag End        132,551        0,0,1280,800        screenshot_0020.jpeg                    User Comment: "There is the redline"        0,0,1280,800        0,0,0,0        screenshot_0021.jpeg
                                Recorded Problem Steps
                                This file contains all the steps and information that was recorded to help you describe the problem to others.
                                Before sharing this file, you should verify the following:
                                The steps below accurately describe the problem.
                                There is no information below or on any screenshots that you do not want others to see.
                                Passwords or any other text you typed were not recorded, except for function and shortcut keys that you used.
                                There were errors during recording. Some information may be missing.
                                You can do the following:
                                Review the recorded problem steps
                                Review the recorded problem steps as a slide show
                                Review the additional details
                                Problem Steps
                                Previous Next
                                Problem Step 1: (4/30/2014 4:11:40 PM) User left click in "caption"
                                Previous Next
                                Problem Step 2: (4/30/2014 4:11:44 PM) User left clicked
                                Previous Next
                                Problem Step 5: (4/30/2014 4:12:21 PM) User Comment: "Created new project with settings specified"
                                Previous Next
                                Problem Step 6: (4/30/2014 4:12:27 PM) User left click on "Windows Explorer (push button)"
                                Previous Next
                                Problem Step 7: (4/30/2014 4:12:31 PM) User left click on "Desktop (outline item)" in "Libraries"
                                Previous Next
                                Problem Step 10: (4/30/2014 4:12:40 PM) User left double click on "STREAM (list item)" in "BDMV"
                                Previous Next
                                Problem Step 11: (4/30/2014 4:13:45 PM) User Comment: "Here is the file I copied via usb direct from my camera not using any software. Just straight copy from the AVCHD folder"
                                Previous Next
                                Problem Step 12: (4/30/2014 4:13:50 PM) User mouse drag start in "STREAM"
                                Previous Next
                                Problem Step 13: (4/30/2014 4:13:51 PM) User mouse drag end in "STREAM"
                                Previous Next
                                Problem Step 14: (4/30/2014 4:13:52 PM) User left click on "Close (push button)" in "STREAM"
                                Previous Next
                                Problem Step 15: (4/30/2014 4:13:55 PM) User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"
                                Previous Next
                                Problem Step 16: (4/30/2014 4:13:57 PM) User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"
                                Previous Next
                                Problem Step 17: (4/30/2014 4:14:01 PM) User left click on "00000.MTS (list item)" in "Add Media"
                                Previous Next
                                Problem Step 18: (4/30/2014 4:14:02 PM) User left click on "Open (push button)" in "Add Media"
                                Previous Next
                                Problem Step 19: (4/30/2014 4:14:09 PM) User mouse drag start in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"
                                Previous Next
                                Problem Step 20: (4/30/2014 4:14:12 PM) User mouse drag end in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"
                                Previous Next
                                Problem Step 21: (4/30/2014 4:14:26 PM) User Comment: "There is the redline"
                                Return to top of page...
                                Additional Details
                                The following section contains the additional details that were recorded that can help find a solution for your problem.
                                These details help accurately identify the programs and UI you used while recording the problem steps.
                                This section may contain text that is internal to programs that only very advanced users or programmers may understand.
                                Please review these details to ensure that they do not contain any information that you would not like others to see.
                                Recording Session: 4/30/2014 4:11:27 PM - 4:14:31 PMProblem Steps: 21, Missed Steps: 1, Other Errors: 0Operating System: 7601.18247.amd64fre.win7sp1_gdr.130828-1532 6.1.1.0.2.1Problem Step 1: User left click in "caption"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: UIF::ThemeButton, caption, #32770Problem Step 2: User left clickedProgram: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: UIF::ThemeButton, #32770, #32770Problem Step 3: User left click on "This project already exists.  Confirm overwrite?  (This action is not undoable!) (push button)"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: This project already exists.  Confirm overwrite?  (This action is not undoable!), This project already exists.  Confirm overwrite?  (This action is not undoable!), This project already exists.  Confirm overwrite?  (This action is not undoable!), Static, #32770Problem Step 4: User left click in "Adobe Premiere Elements"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: Adobe Premiere Elements, PremiereElementsProblem Step 5: User Comment: "Created new project with settings specified"Program: UI Elements: Problem Step 6: User left click on "Windows Explorer (push button)"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: Windows Explorer, Running applications, Running applications, MSTaskListWClass, Running applications, MSTaskSwWClass, ReBarWindow32, Shell_TrayWndProblem Step 7: User left click on "Desktop (outline item)" in "Libraries"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: Desktop, Namespace Tree Control, Tree View, SysTreeView32, Namespace Tree Control, NamespaceTreeControl, CtrlNotifySink, DirectUIHWND, DUIViewWndClassName, Libraries, ShellTabWindowClass, Libraries, CabinetWClassProblem Step 8: User left click on "Page down (push button)" in "Desktop"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: Page down, Vertical Scroll Bar, ScrollBar, CtrlNotifySink, DirectUIHWND, ShellView, SHELLDLL_DefView, CtrlNotifySink, DirectUIHWND, DUIViewWndClassName, Desktop, ShellTabWindowClass, Desktop, CabinetWClassProblem Step 9: User left double click on "BDMV (list item)" in "Desktop"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: BDMV, Items View, DirectUIHWND, ShellView, SHELLDLL_DefView, CtrlNotifySink, DirectUIHWND, DUIViewWndClassName, Desktop, ShellTabWindowClass, Desktop, CabinetWClassProblem Step 10: User left double click on "STREAM (list item)" in "BDMV"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: STREAM, Items View, DirectUIHWND, ShellView, SHELLDLL_DefView, CtrlNotifySink, DirectUIHWND, DUIViewWndClassName, BDMV, ShellTabWindowClass, BDMV, CabinetWClassProblem Step 11: User Comment: "Here is the file I copied via usb direct from my camera not using any software.  Just straight copy from the AVCHD folder"Program: UI Elements: Problem Step 12: User mouse drag start in "STREAM"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: STREAM, CabinetWClassProblem Step 13: User mouse drag end in "STREAM"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: STREAM, CabinetWClassProblem Step 14: User left click on "Close (push button)" in "STREAM"Program: Windows Explorer, 6.1.7600.16385 (win7_rtm.090713-1255), Microsoft Corporation, EXPLORER.EXE, EXPLORER.EXEUI Elements: Close, STREAM, CabinetWClassProblem Step 15: User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: UIF::ThemeButton, class UIF::SubWorkspaceView, class UIF::Pane, class UIF::PaneContainer, Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel, PremiereElementsProblem Step 16: User left click in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: UIF::ThemeButton, class HSL::GetMediaOnlyButtonsView, class HSL::GetMediaButtonsView, class HandlerOrganizer::OrganizerView, class UIF::Pane, class UIF::PaneContainer, Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel, PremiereElementsProblem Step 17: User left click on "00000.MTS (list item)" in "Add Media"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: 00000.MTS, Folder View, FolderView, SysListView32, SHELLDLL_DefView, Add Media, #32770Problem Step 18: User left click on "Open (push button)" in "Add Media"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: Open, &Open, Button, Add Media, #32770Problem Step 19: User mouse drag start in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: class HSL::MediaGridView, class HSL::MediaGridFilterView, class HandlerOrganizer::OrganizerView, class UIF::Pane, class UIF::PaneContainer, Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *, PremiereElementsProblem Step 20: User mouse drag end in "Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *"Program: Adobe Premiere Elements 8.0, 8, 0, 1, 0, Adobe Systems Incorporated, ADOBE PREMIERE ELEMENTS.EXE  -SPECIFIER PREMIEREELEMENTS-8.0 -NOSTARTUPSCREEN -NOABOUTDIALOG, ADOBE PREMIERE ELEMENTS.EXEUI Elements: class HandlerTimeline::TrackContentView, class HandlerTimeline::TrackView, class HandlerTimeline::TrackTypeViewArea, class HandlerTimeline::TrackViewArea, class HandlerTimeline::TimelineView, class UIF::Pane, class UIF::PaneContainer, Adobe Premiere Elements - C:\Users\chris\Desktop\4-28-14 Tap\My Project.prel *, PremiereElementsProblem Step 21: User Comment: "There is the redline"Program: UI Elements:
