2 Replies Latest reply: Apr 30, 2014 7:25 AM by aufer RSS
    Can forms creation be automated ?
    aufer Community Member
      Is there a way in LiveCycle to automate the creation of Objects at Design time ? Not a Dynamic form.
      I need a way to create a table (or other Objects) with multiple Rows based on code !
      Example: I have an Excel document with multiple rows and columns & need to create a simple form
      Question                        | Answer | Comments |
      Did you like the Product | Yes, No |                  |
      On a Scale of 1 to 10     | ##         |                  |
      Other Comments            |              |                  |
      What I would like to do is write code that automates the whole process ( I will write the translation from the spreadsheet to code ) .
      The code should be similar to
      1. CreateATable ( "Table1", #Rows, # Columns, xPos, yPos )
      2. Table1.Row0.Cell1.Text = "Question" ; Row0.Cell2.Text = "Answer" ; Row0.Cell3.Text = "Comments" ;
      3. Table1.Row1.Cell1.Text = "Do you like the Product"
          Table1.Row1.Cell2.ObjectType = DropDown.Field ; Row1.Cell2.ObjectValues = "Yes", "No" ;
          Table1.Row1.Cell3.ObjectType = TextField
      etc.
      ** This code will run at Design time to allow extra formatting. Need the form to be XFA.
      Aubrey
        • 1. Re: Can forms creation be automated ?
          George Florentin
          I think it's possible and here is how I would do it:
          1. you create a table in designer, with header and 1 repeated row, minimum instance = 0;
          2. you create an XML file where you store the data that should be inserted into the table;
          3. you store the XML from step 2 in a global variable (File -> Form Properties -> Variables). The global variable has a limit of ~32.000 chars so I recommend a minified XML;
          4. you create a function (or ask me nicely ) that parses the XML and retrieves the data;
          5. you loop on that data and for each entry you add an instance of the Row in table from step 1 and populate it with data extracted from the XML.
          Step 5 can be called at initialize or form:ready.
          • 2. Re: Can forms creation be automated ?
            George,
            Thanks for the answer.
            I would greatly appreciate the code that parses the XML & retreives the data.
            Can you send me examples for step 5.
            i.e. Code to add an instance of the Row in a table & populate it with data extracted from the XML.
            My preference would be to skip the XML altogether & auto generate the code for Step 5 outside of LiveCycle as I am comfortable with other coding ( specifically VBA ) which would allow me to generate code directly from a spreadsheet. ( I will post the solution with code after ).
            I am relatively new to LiveCycle so excuse this question.
            Does the initialize or form:ready execute during the form creation ?
            Will the text, rows, textfields etc be prebuilt & prepopulated if I were to open this PDF if Adobe Reader or some other app ?
            Thanks again
            Aubrey
